liamscor
Message 11 of 14
Re: SmartHub not suitable for Ultrafast 2
I Checked in the Hub, and it says the sync speed is 1000Mbps download
1000Mbps upload
Everyone I speak to in BT says the same thing.
Dave859
Message 12 of 14
What they are giving you is the old by infinity 4 speeds, it could be the hub but if you haven't got a third party router to check you can't know for sure if it's the hub or open reach not upgrading your fibre to the new speeds. at first I was told the same but they will give in like they did with me, I sent the guy on the phone a link to this thread and he worked with the firmware team and open reach and it was fixed in 50 minutes.
DanielS
Moderator
Moderator
Message 13 of 14
Hi @liamscor,
I'd like to get this all checked for you. I've sent you a private message so we can help. If we can't help personally we'll get the FTTP team to fully investigate.
DanielS
DanielS
Moderator
Moderator
Message 14 of 14
Thanks for getting in touch with me @liamscor.
I'm happy that I was able to get this all sorted for you Smiley Happy
Have a great day,
DanielS
