I had my Fire 1 from BT fitted yesterday and everything is fine except the mess of cabling re power adapters plugged into my power extension lead. I'd like to briefly unplug the ONT's power adapter and repostion this id then plug it back in again. Will this be OK or cause problems? I mean power outages have same effect!
Solved! Go to Solution.
Yes it will be ok.
Un plugging the ONT from power is fine, just don't move the ONT itself. As winter is now fast approaching, remember to never plug in any kind of heater to a multi-gang extender!
I cannot work out without removing the clunky, boxy white multiway adapter (part of a tower version) plugged into my 2 gang socket, whether there's enough space between its sockets for the rather bulky Smart Hub 2 mains adapter and the slimmer white ONT power adapter. Often, some are so bulky that they take up too much room for another adjacent adapter to fit in.
Not sure what you mean? They're some of the smaller PSUs I've come across. I have a Draytek with a similar sized PSU to the SH2 and a separate ATA plugged in as well. No problem.
