KAdamsy
Message 1 of 4
Re: Unstable Connection / Constant Dropouts / BT ignoring Issue
Got roughly the same problems anyone see any problems here:
Product name:
BT Hub 6A
Serial number:
+084319+NQ70570491
Firmware version:
SG4B1000B540
Firmware updated:
18-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 21 Minutes 4 Seconds
Data rate:
11.70 Mbps / 44.88 Mbps
Maximum data rate:
11765 / 52471
Noise margin:
6.1 dB / 6 dB
Line attenuation:
21 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
486 MB Uploaded / 218 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-T76C
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-T76C-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A4:08:F5:A5:3F:1F
Software variant:
Boot loader:
7.33.1
3 REPLIES 3
imjolly
Message 2 of 4
i moved your post as the previous thread was over a year old
connection speed is maybe slightly lower than attainable but noise margin is normal 6db
are you using test socket with filter to see if that helps your stability by eliminating your internal wiring and possible faulty faceplate
try quiet line test dial 17070 option 2 should be quiet and best with corded phone
enter phone number and post results  remember delete number  https://www.btwholesale.com/includes/adsl/main.html
KAdamsy
Message 3 of 4
Quiet line test is fine, tried the test socket same issue. Phoned this morning had my line reset and within an hour i had a drop out knocking my speeds down to 26meg 😞
and heres the other test (not sure how to add it so it show properly so hope its ok)
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)66.646.715.11040AvailableAvailable--
VDSL Range B (Impacted)54.834.313.4727.4AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 13.5--11.5 to 15Available----
WBC ADSL 2+ Annex MUp to 13.5Up to 1.511.5 to 15Available----
ADSL MaxUp to 7.5--6.5 to 8Available----
WBC Fixed Rate2 ----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date21-07-2018
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined
Mustafa_Islam
Message 4 of 4
Could just be your hub resyncing, or maybe the heat is getting to it 🙂
Leave it on for a few days and allow the restarts or orange light plague go through by itself. Don’t restart it yourself as it will make ur line seem unstable to BT’s line automatic management.
____________________________
If I helped out then leave my reply a Kudos by clicking the thumbs up button
