MatthewG-
Message 1 of 40
Re profiling or Line Fault ?
I have been with Infinity 1 over a year now and my speed have been consistent of 9.5 Up and 38 down.
Recenlty I renewed my contract 3 week ago so I can get the abit more speed because my line is capable of 46Mbs. but will not be active untill my current contract expires.
But last saturday somthing strange happened to my download speed when i droped connection and resycned early hours.
So I restarted my router and everying was back to normal apart from every day I have been losing 3mbs for my max rate on my line. Around 11AM today it was at 6 SRN up and 4.5 SNR down and 29Mbs
As I was tryping this message my router disconnected and Resycned with a speed of asd.PNG
39 REPLIES 39
MatthewG-
Message 2 of 40
Re: Re profiling or Line Fault ?
I am not sure what is going on My line droped at 7AM this moring with a new lower download speed.
But I know that if I restart my router that the speed will be back to 46Mbs but capped at 38Mbs so I am not sure what to do.
The thing is I have had no problems in a very long time, the longes it has been active solid was 76 days and then it started droping ever 14 days. Now thing are going to hell 😞
I was going to restart my router but if it is DLM that going to cause more problems.
The Modem/Router combo is an TD W9980 TP Link
Advice Much Appriciated
MatthewG-
Message 3 of 40
well is been 2 hours and the max speed just up to 38Mbs this is with out Disconnect so there is somthing strange happening...
Message 4 of 40
you don't need a reset for max rate or noise margin to change whether up or down  will get a reset if the actual data rate changed
MatthewG-
Message 5 of 40
@imjolly
Yes I get what you are saying, MAX is to with with SNR and Current Rate is the cap on connection.
For example, Just been taken.
what has been happening is my connection dropped on Saturday and resynced \/
So after Saturday the connection was OK apart from the SNR and Max data rate dropping by 3 Mbs a day. Yesterday the connection dropped at 12PM and the SNR resycned at \/
I looked today and the connection dropped at 7AM with a new SNR and current rate the SNR was 5.8 at 1PM but around 3 PM it jumped to 7.8
MatthewG-
Message 6 of 40
Ok I have not droped sync as of yet but the routers SNR dont seem to be look right
1AM
8 May 16
11AM
8 May 16
MatthewG-
Message 7 of 40
I have disconnected again 😞 at 2PM Today.
Connection lasted 3 days
gt94sss2
Message 8 of 40
Do you have the latest firmware for your modem?
do you have another modem you could try?
Message 9 of 40
the drop in connection has not affected your connection speed as you still have 40mb.  is there any noise on quiet line test?
MatthewG-
Message 10 of 40
@gt94sss2 Yes the router is up to date. I only have a Hub 5 but I don't like because of the software restrictions.
@imjolly
Ok so I unplugged my wireless phone and plugged in a corded phone and did the test the line sounded clean, after the test I looked at my computer and it shows it disconnected again during the test because I left a Steam Call.
Connection only up 6 hours before disconnect again 😞
