Message 21 of 40
Re: Re profiling or Line Fault ?
Huawei
MatthewG-
Message 22 of 40
So its G-INP enabled 🙂
So the Hub 5a does not have it that setting. Does the TD-W9980 Or do I need a Hub5 B.
I am only thinking about G-INP because some people have said it fixed there problems in the past.
Plus how did you find out @licquorice
Message 23 of 40
There are no user configurable settings. G.Inp isn't a magic bullet either.
https://www.telecom-tariffs.co.uk/codelook.htm
MatthewG-
Message 24 of 40
@licquorice Ah that explains why I can't find it in the setting 🙂
Well I will look after work and update.
TheTvMan001
Message 25 of 40
The TD-W9980 is G.NIP but only with the latest Firmware, some older versions are not.
MatthewG-
Message 26 of 40
@licquorice
I can find the cabinet P33 but I can't find where it says the make of cabinet.
Also I have had a look at my router and it is up to date. I take it G.INP is controlled via the cabinet since I can't find anything in the router settings.
Also no drop so far in my connection 3 days .
Message 27 of 40
@MatthewG- wrote:
@licquorice
https://www.telecom-tariffs.co.uk/codelook.htm?xid=618310&cabinets=14200
Shown under vendor information
Indeed
MatthewG-
Message 28 of 40
well My connection has droped again 😞 5 days here is my router stats
no one has used the phone.
MatthewG-
Message 29 of 40
My line seem to be stable once again but my line is capped at 31 and max download is 40.
I recontracted my infinity 1 to get a better deal and get the new download speed the rollover of the contract was today but my speed has not increasted or resynced. I know i wont get the full 52Mbs due to my cab
DSL check
Message 30 of 40
moving to the new infinity 1 package 55/10 does not mean you will get a faster connection speed especially with an attainable of only 40mb  this was not restricted because your were on infinity 1 40/10mb package
