wobbly64
Newbie
Message 1 of 14
Re: slow broadband speeds.
my broadband spped has dropped from 45mbps 6 weeks ago to 1.86mbps
i have tried on numerous occassions to get it sorted online and by phone so as a last resort i am now trying on the forum.
i am 20 metres from the exchange
i am the only user of the broadband
i am connected via ethernet and have carried out all the tips suggested by BT
1. Product Name: HomeHub5 2. Serial number: +076284+1448006348 3. Firmware version: v0.07.03.0814-BT (Type B) Last updated [Unknown] 4. Board version: 01 5. VDSL uptime: 1 days, 03:30:17 6. Data Rate: 800 / 1995 7. Maximum Data Rate: 29713 / 21816 8. Noise Margin: 31.4 / 35.9 9. Line Attenuation: 0.0 / 7.5 10. Signal Attenuation: 0.0 / 0.0 11. Data sent/received: 55.2 MB / 756.4 MB 12. Broadband username: bthomehub@btbroadband.com 13. BT Wi-fi: Yes 14. 2.4GHz wireless network/SSID: BTHub5-8KHS 15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s)) 16. 2.4GHz wireless security: WPA2 Only (Recommended) 17. 2.4GHz wireless channel: Automatic (Smart Wireless) 18. 5GHz wireless network/SSID: BTHub5-8KHS 19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s)) 20. 5GHz wireless security: WPA2 Only (Recommended) 21. 5GHz wireless channel: Automatic (Smart Wireless) 22. Firewall: Default 23. MAC Address: 4c:09:d4:42:2f:a8 24. Software variant: - 25. Boot loader: 0.5.0-BT (Tue Jun 17 18:52:56 2014)
13 REPLIES 13
Message 2 of 14
can you enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
are you connected to the test socket or do you have a SSFP?
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
are you having problems with hub dropping connection or have you been manually resetting or both just your noise margi is very high at 31.4db as normal about 6db
wobbly64
Newbie
Message 3 of 14
i have ssfp socket
done quiet line test and no noise
hub does not drop connection
wobbly64
Newbie
Message 4 of 14
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High Low High Low
FTTC Range A (Clean) 80 80 20 20 -- Available
FTTC Range B (Impacted) 80 61.9 20 12.2 -- Available
WBC ADSL 2+ Up to 15 -- 13 to 16.5 Available
WBC ADSL 2+ Annex M Up to 15 Up to 1.5 13 to 16.5 Available
ADSL Max Up to 8 -- 7 to 8 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
Message 5 of 14
distance from the exchange is not important for fibre  - it is distance from your street cabinet
hub was reset 1 day ago was that manual?
Message 6 of 14
with that estimate I would be expecting 80mb conenction.  have you tried conencting to test socket with a filter and see if that changes anything
wobbly64
Newbie
Message 7 of 14
yes i am 20 metres from the street cabinet and yes i did the manual reset
wobbly64
Newbie
Message 8 of 14
yes i have tried with a filter also and it makes no difference
i was getting 45mbs 6 weeks ago but the speed has been dropping daily
wobbly64
Newbie
Message 9 of 14
sync speed or line rate to my property at this moment is 1.99 mb
Message 10 of 14
if you have used test socket without improvement and quiet line test on then I would contact customer services and get engineer visit
08001114567
interference causes
