Having same problem since yesterday. Have checked all cables, rebooted home hub, everything. The ethernet cable into the back of the PC is flashing orange/yellow. Checked BT status for my line, says there is nothing wrong. Any chance someone can check for me? thanks
this is a customer help customer forum and your post does not go to BT
what colour is hub light?
try quiet line test dial 17070 option 2 should be silent and best with corded phone
can you post stats from your router
