Roblevelo
Message 11 of 13
Re: Reallistic Infinity2 Speed increase
I have two laptops that are both the same make model etc. Both run the same Ethernet card with the same driver so on your advice I tried the other laptop not expecting any difference. The results are posted below.
Results Image not loaded
1. Best Effort Test:
Download Speed : 41.42 Mbps
2. Upstream Test:
Upload Speed : 3.81Mbps
Clearly a big difference. Similar results on the second laptop for wireless (when sitting close to the router).
So there is someissue with the first laptop. Not sure where I'll start with that but many thanks for all your help in this.
Roblevelo
Message 12 of 13
Perhaps I should add that the BTDesktop help speedcheck remains low on the second laptop at around 23Mb/s.
Message 13 of 13
I would advise that you remove BTDesktop help. It's a piece of junk that is not needed on your computer and can cause problems. Once you have done that recheck your speeds.
