Message 1 of 2
Really slow speeds
Hello,
Recently, my roommates got the internet sorted.  However, my speeds are really slow. We went for the 55 download speed and 10 upload speed packadge split between 4 people. I realised the internet speeds were really slow once I connected my pc via the ethernet cable. I am getting around 3 Mbps, on internet speed tests however this seems inconsistent. Also my ping when playing games sometimes goes to 800 whereas on the tests it displays it as around 15. Further, I tested the internet speed before anyone was up and using the internet from other devices and the speeds seemed fine, but once someone starts using the internet on other devices I start having these issues. Another thing to note is that, one of my roommates stated her internet speed being really slow, whils another said it was ok.
So, I just wanted to ask for help in fixing this.
Thank you.
1 REPLY 1
Message 2 of 2
Re: Really slow speeds
the hub does not share out bandwidth equally so you are obviously suffering with 4 people using the fixed amount of bandwidth  your only real solution is to buy a 3rd party router like tplink 9970 for about £30/35 which enable the bandwidth to be allocated to specific devices that way everyone can get an alloted share
there is nothing BT can help you with that
