wibbly
Message 1 of 7
Recently re-contracted but still traffic shaped
I re-contracted on the 12th (5 days ago) and I now have 50GB BTCloud, and all the other services, but I seem still to be throttled. Does it take longer that 5 days for the throttling to be sorted or has something gone wrong?
On BT Infinity 2 (76Mbps) and get up to 70Mbps using speed tests during quiet periods
Throttling
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: Recently re-contracted but still traffic shaped
Hi Wibbly,
Apologies for the confusion since moving over to the "totally unlimited" package.  I can check that everything is the way it should be from here.  To get in touch, click on the "about me" section of my profile where you'll see the link to "contact the mods"
Thanks a million,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
wibbly
Message 3 of 7
I'm having a dim moment - got here
http://community.bt.com/t5/user/viewprofilepage/user-id/130414
But can't find the contact the mods link 😞
Edit, just found the link to PM you, will use that...
Message 4 of 7
should ba a contact us link with form to complete not a PM
wibbly
Message 5 of 7
Got the link, request made. Thanks 🙂
Either this wasn't showing before or I need new glasses
Tags (1)
Moderator
Moderator
Message 6 of 7
@wibbly
I hold my hands up. It was my fault you couldn't see the link before Smiley Surprised
You've got the form filled in now and that's the main thing! Smiley Happy
Robbie
Kudos”Kudos”
Message 7 of 7
post deleted by poster
