NorthEasterner
Message 1 of 11
Relocation of BT Hub
Good Evening
I've recently moved into new house and finally got re-connected today. However the master socket is in a inconvenient location and the engineer when he came to install the service was unable to install the hub in one of the bedrooms (for a reason unknown).  I do have an extension socket in the living room however the cable is damaged so is redundant.
Is it possible to have a new extension running from the master socket located in hall way to the bedroom - the cabling would have to run externally.
Or any possibility of running a cable from the grey box on the wall of the property to the bedroom?
Ideas/Advice is welcomed and greatly appreciated
https://ibb.co/dQQNvn (Hub)
https://ibb.co/b89FFn (Master Socket)
https://ibb.co/dsKFFn (Grey Junction Box)
10 REPLIES 10
Message 2 of 11
Re: Relocation of BT Hub
Please upload the pictures to your forum gallery.
Here is how to post pictures.
 https://community.bt.com/t5/help/faqpage/faq-category-id/images#images
NorthEasterner
Message 3 of 11
NorthEasterner
Message 4 of 11
it will not allow me to upload other 2 photos as file is too big - tried to export it lesser quality but still not working
NorthEasterner
Message 5 of 11
Message 6 of 11
if you run from the external grey box then you will have star wiring which will have an adverse effect on you broadband conenction
Message 7 of 11
how is the wiring to your livingroom extesion socket damaged?  at a place you cannot see or reach?  you could run a data extension cable from the terminals on the back of the front detachable section
this may help https://www.openreach.co.uk/orpg/home/helpandsupport/how-toguides/howtoguides/downloads/NTE5C_Instru...
NorthEasterner
Message 8 of 11
The previous owner had done it at what looks a cheap job - no socket per say but just a little port thing dangling off the cable. I don't really wish to have it in living room either.
Looks like a data extension is the way forward.
Message 9 of 11
If you are not going to use it then I would disconnect/remove it from the master socket connections to avoid any interference
NorthEasterner
Message 10 of 11
It has been disconnected entirely 🙂
