Hi all im experiencing an issue with an unstable line? here is the message im getting followed by an image "
Your DSL line appears to be unstable. DLA (Dynamic Line Adjustment) which enabled by default already adopted necessary changes and ensure stability"
Solved! Go to Solution.
DLM is on all the time on your line and will make alterations to maintain a stable connection so it would appear to be doing its job.
See link
http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
Apart from the message you are getting is there any other symptoms of an unstable line.
thanks for your reply and to your question no everything seems fine i just saw the message and thought something maybe wrong?
all the best
Couple of points, VDSL should be 17A rather than 30A, and G.Inp should be enabled if you are connected to an Huawei cabinet.
It won't hurt to enable it anyway, you may see an improvement in speed if connected to a Huawei cabinet, but will have no effect if connected to an ECI.
Disable what other? Or do you mean change 30A to 17A for VDSL profile, in which case, yes.
G.vector isn't available yet, so yes, disable that.
