Storm
Expert
Message 11 of 17
Re: Replacement Router - Specific requirements
Not sure about the wireless dropping, it seems fine on my Samsung Galaxy SII but as far as port forwarding is concerned do you by any chance have a HH3 Type A?
I ask as I had to get replaced the original Type A I was sent with a HH3 Type B as port forwarding doesn't work on the Type A, it's fine on the Type B.
Speak to someone in tech support and explain you need port forwarding and specifically ask for a Type B, worth a try and will be the only free option.
If you already have a Type B then I'm not sure.
MadPanther
Message 12 of 17
Hi
My S3 has a static IP Address and DHCP is disabled on the HH3, so I don't think that is the issue.
Any recommendations for a £50.00 replacement for the HH3 ? VPN termination would be nice, but not vital !
Message 13 of 17
How about the TP-Link TL-WR1043ND, its in use by other people, costs about £38.
MadPanther
Message 14 of 17
Thanks Keith, that looks like a good option !
Do you know of any others that do VPN termination ?
thanks 😄
Message 15 of 17
There is a small list here, recommended by other users, which is where my recommendation comes from.
There is also a link to the main thread on that page.
Replacements for BT home hub 3
anthonyUK
Expert
Message 16 of 17
The TP-Link Keith mentioned can run OpenWRT so should be able to be a VPN endpoint such as OpenVPN.
MadPanther
Message 17 of 17
Thanks, I'd spotted that last night and forgot to update my post.
I've upgraded my S3 to 4.1.2 today and the wireless seems a lot more stable, not noticed the drop outs.
Now if I could get the port forwarding working on the HH3 then this would be solved.
I'll have another look at the TP-Link 😄
