Message 1 of 19
Request DLM reset
Hi,
I am on BT Infinity2 and currently banded at 67000000 bps
The banding has been there a number of years now.
I have replaced my modem/router combo a few times since, but the banding has never been removed.
How should I proceed?
18 REPLIES 18
Message 2 of 19
Re: Request DLM reset
there isn't an FTTC band at 67mb
can you post your router stats please
at present only way out of banding is to get a broadband engineer visi and to fix a fault before they can request a DLM reset
ISP are allowed to request DLM resets in certain crieria but so far there is nothing to say that BT/mods are able to do that at present
Message 3 of 19
Sorry Mr Jolly, you are a little bit out of date:
https://www.ispreview.co.uk/index.php/2018/02/ability-reset-openreach-fttc-broadband-dlm-profiles-ar...
Can anyone else tell me how to proceed?
Message 4 of 19
@spazicus
I am mnot out of date hence why I said ISP can request DLM reset under certain criteria but at present BT have not made that facility available and mods at present, i stress at present, cannot request the DLM reset
you are not in a banded profile anyway at 67mb
Message 5 of 19
"you are not in a banded profile anyway at 67mb"
You should quit typing mate:
   DS Actual Rate          : 67000000 bps   US Actual Rate       : 20000000 bps
   DS Attainable Rate      : 73855816 bps   US Attainable Rate   : 21547602 bps
OBVIOUSLY banded...
Message 6 of 19
not according to this  https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
post full stats
Message 7 of 19
Please do me a favour and delete your above posts. The thread is getting full of the innacurate rubbish you are posting.
You are NOT helping.
Moderator
Moderator
Message 8 of 19
Thanks for your posts @imjolly. You are right when it comes to requesting DLM resets for FTTC at present.
Hi @spazicus,  if you believe you are being banded, and want it checked, please contact our help desk on 08001114567. Our agents will run through a few checks for you and if an engineer is needed they can discuss that with you. DLM resets for FTTC are supposed to be made available at some point but not yet.
Remember to keep it friendly.
DanielS
Message 9 of 19
Hi DanielS.
So BT Retail can't request a DLM reset like Plusnet currently can and are doing, without an engineer visit?
See: http://forum.kitz.co.uk/index.php/topic,21116.0.html
Will this functionality be added any time soon for BT Retail?
Thanks,
Moderator
Moderator
Message 10 of 19
Not at this moment in time @spazicus. It's a different type of request for resetting the DLM. It's not as simple as it is for copper. Plus, they're trialling it with selected Customers only. It's not nationwide as of yet.
As soon as it's available I'll know as I'm one of the admins between BT Retail and BT Wholesale.
If you get speaking with one of our agents get them to check what profile you are on. They should be able to check.
DanielS
