Message 1 of 2
Request for Info
Hi all
Does anybody know the minimum height required from OH lines to ground level?  I have fttp installed without any problems.  My neighbour has also recently had fttp installed from the same pole which carries the fibre across my garden (I've no problem with the routing/direction).  It is approx 65m in length.  However, it runs through some fruit trees which partially supports it but, in the open area, it "dangles" to approx 3m (10'  6'') high and easily reachable.  I don't want to damage it with long eqpt etc.  Any views on this?
1 REPLY 1
Message 2 of 2
Re: Request for Info
from a previous post it seems that should be 3m or more
https://community.bt.com/t5/The-Lounge/Overhead-Lines/m-p/2198212#M26536
