Message 1 of 6
Request installation of Infinity-enabled cabinet
Getting pretty fed up of 2.4mbps in a town in 2013... it's like going back 5-8 years!
We (100 homes in the little estate) are served by a very old cabinet which orignally served a factory and a factory only. Openreach haven't upgraded the cabinet for Fibre, meaning I am stuck on 2.4mbps forever more until the next roll out!
Does anyone know where I can request the installation of a cabinet?
5 REPLIES 5
Message 2 of 6
Re: Request installation of Infinity-enabled cabinet
FYI, I am on the Ryde exchange, Cabinet 40
Distinguished Guru
Message 3 of 6
Hi
Have a look HERE//
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 6
Yep, as per always...
WBC ADSL
ADSL Max
WBC Fixed Rate
Fixed Rate
I know that it is not enabled... I just want to know how I can request that it is
Distinguished Guru
Message 5 of 6
You have to ask Openreach
If not, I'll try again 🙂
Distinguished Guru
Message 6 of 6
Telephone Exchange areas PCPs (Cab) are Infinity enabled in phases, so although your's is not currently showing a date it may get included in the future. These dates are not in the public domain.
