Message 1 of 12
Returning customer and my Ip profile set too low ?
i just switched to Bt from Plusnet ,i had the same super fibrepackage and i was on a stable 76Mb for 3+ years , as soon as the switch was done my profile on BT was set to  55Mb  with speed going as slow as 35MB download.. so i have some questions
1: why was my profile set that low to the point where you barely deliver the minimum speed ( which is 50Mb )
2: why when going to the  online chat to ask for my profile to be set correctly the team all of sudden find a fault outside my house ( when i had no issue with my fibre for 3+ years prior to switch to BT )
3:can someone switch my profile to the correct speed and then monitor
4: do not come with the " we have to monitor your line for 14 days for the fibre to stabilize " we all know fibre does not need that and it is just a pathetic excuse for provider to get rid of the " 14 days cooling off coming with customer right " ( If your contract started less than 14 days ago - You're allowed a 'cooling off' period during which you can change your mind and cancel it. )
So i'm asking this to be sorted asap ,i want the max speed my line can handle ,which i know is around 76Mb since i have had that speed for 3+ years without any issues.
thank you
11 REPLIES 11
Message 2 of 12
Re: Returning customer and my Ip profile set too low ?
this is a customer help customer forum sp posts are not going to BT
it sounds more like you are on the lower package with 55mb max and not the 80mb package which is bit more expensive
post stats from your router
you ip profile is based on your connection speed
Message 3 of 12
I'm on superfast fibre2 unlimited
Product name:
BT Hub 6A
Serial number:
+084316+NQ71231791
Firmware version:
SG4B1000B540
Firmware updated:
10-Jul-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 1 Hours 21 Minutes 51 Seconds
Data rate:
20.00 Mbps / 57.08 Mbps
Maximum data rate:
22458 / 69061
Noise margin:
6.9 dB / 6.3 dB
Line attenuation:
15.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
94 MB Uploaded / 4467 MB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:8E:78:18:B4:5B
Software variant:
Boot loader:
7.33.1
 actual speed test
Download Speed(Mbps): 40.08 Mbps
Upload Speed(Mbps) : 19.86 Mbps
Ping Latency(ms): 37 ms
So i'm on the 80Mb package but setup as the 50Mb package ?
regards
Message 4 of 12
no from your stats you are on superfast 2 up to 80mb with an attainable of 69mb and current conenction speed of 57mb
can you enter your phone number and post results  remember delete number but leave exchange and cab https://www.btwholesale.com/includes/adsl/main.html
Message 5 of 12
i know i can reach 76Mb i have been on that speed with Plusnet for 3+ years...
Message 6 of 12
Test on this sunday 02-09 @14.00
Test not conclusive and i was not able to du further test since i got a " The Tap1 test was not conclusive for your broadband connection" error afterward ,but i noticed they slightly raised my ip profile from 55 to 64..which is still not the " 67Mb average promise when i recontracted " i know from the past 3 years with plusnet that my line can handle a stable 76Mb ,so hopefully they will raise it to the max speed my line can handle .. still need thoses speed drop well under the mimimum  to be fixed .
Message 7 of 12
obviously if you speed has improved since you posted hub stats there has been a reset in your conenction giving an improved speed.  the 67mb quoted (as per OFCOM) is an average
as you are on Huawei cab then if you maintain conenction then G.INP should be activated by DLM in 10/14 days which should give you a bit more speed and a lower about 3db noise margin - just maintain conenction as this is automatic
Message 8 of 12
still way under what i was promised and what my line can handle  ,that is the reason i'm not happy , fake promises
Message 9 of 12
what connection range did BT quote in the letter your received - speed quoted by BT are conenction speeds even though it mentions download speed  If you are within estimated range then unlikely BT will help
your speed should still improve if you can maintain a stable connection and G.INP is activated
the 67mb quoted (ofcom required) ia an average not what you will get - you may be higher or lower than the average
Message 10 of 12
everything was done online , no letter received whatsoever.
