it Happens in the morning aswell so nothing to do with peak times I don’t undestand why 18months ago my speed was 20meg more,Xbox connected via Ethernet and 4K sports were all working surley as time passes technology should be better
Until we can see the connection information from the home hub, its difficult to say.
When you get home can you also check if there is any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
@vdudleycave wrote:
The Xbox works with a old hub5 so it definitely to do with the new smart hub
Then use the home hub 5 instead, there is nothing special about the home hub 6, in fact the restriction on wireless channel selection makes it worse.
@Keith_Beddoe wrote:
@vdudleycave wrote:
The Xbox works with a old hub5 so it definitely to do with the new smart hubThen use the home hub 5 instead, there is nothing special about the home hub 6, in fact the restriction on wireless channel selection makes it worse.
I agree with @Keith_Beddoe or you can do even better and get a third party router. They start from £30 and will be far superior than ISP supplied rubbish.
from personal experience the wireless coverage by the HH6 is better than that of the HH5
Here is my connection details from the hub hope this is what you need
You are connected at 47Mbs which is at the bottom end of range A.
Was there any noise on your phone call, when you did the quiet line test?
If you hear noise when doing quiet line test from test socket with filter then you need to report a phone fault not broadband to 151. Get rid of noise and broadband should improve
