Message 31 of 42
Re: Returning customers after 18months not happy
I’ve plugged micro filter in and connected phone and broadband to it,done a speed test on my phone via speedtest app and my download is 150meg and upload 250meg but my router is flashing orange and purple surly my speedtest app shouldn’t work
Message 32 of 42
You are probably connecting to your mobile network instead.
Click on this link and see what the page says BT Broadband check
Message 33 of 42
You are connected via your mobile on the EE network, right ?
You are routed via an Orange cell site.
Message 34 of 42
Yes I’m on EE, the broadband just flashes orange and purple with both phone and broadband connected to the micro filter
Message 35 of 42
Do you get any dial tone on the phone while plugged into the test socket?
If you don`t, then your master socket is wired up wrong, and the line is coming in on the bottom removable section instead, which is totally wrong, and will not work properly.
Message 36 of 42
I’m still getting a dial tone with phone and broadband connected to micro filter just not broadband connection
Message 37 of 42
Message 38 of 42
Something is very wrong with your internal wiring, its almost like you have another filtered socket somewhere, which is only passing the phone signal to the back terminals of the master socket, and passing the broadband signal to the back of that bottom section.
What date was your BT service activated, this is important?
Message 39 of 42
11th of December,don’t know if it helps but I’m still able to log onto bt on an old account from over a year ago it was never closed when I cancelled that account
Message 40 of 42
Right, you are entitled to a free visit to sort out the wiring and speed issue.
See Early Life Failures - moderator post
I will ask a moderator to arrange this for you.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
It will be tomorrow before they post that link, meanwhile, I would just put things back as they were.
That wiring error will be the cause of all your problems.
