andysilve
Message 21 of 25
Re: Router dropping internet connection and no landline?
The Openreach engineer has been and if I understood him correctly has found a cable fault between junction boxes ,so underground,he has connected to another set of cables bypassing the fault which should solve the problem (I hope) I can report that 4 hours from repair we have had no issues .
andysilve
Message 22 of 25
Had a third Openreach engineer out today who ran several tests but couldn't really find anything faulty but mentioned something about possibly being an interferance issue ?? Which given the line issue we have had I think unlikely.I'd appreciate it if a Mod could keep an eye on my connection for the next week or so as will I but I don't always see the di connects as the recent ones have been mostly overnight  .
PaddyB
Moderator
Moderator
Message 23 of 25
Hi @andysilve,
Thank you for posting back. I'll keep an eye on your connection over the next few days. I'll give you a call next week to see how the connection is performing.
If you notice any stability issues in the meantime, please post back and I'll run a few checks on your line.
PaddyB
PaddyB
Moderator
Moderator
Message 24 of 25
Hi @andysilve,
I gave your mobile number a quick call, I'm sorry I didn't get speaking to you today.
The reason for my call was to see how things are with your connection? I've ran a few checks and its looking good at the moment. How are things at your end?
If your still experiencing issues with your connection, please post back.
PaddyB
andysilve
Message 25 of 25
Hi Paddy yes I noticed a missed call .All seems good I will carry on monitoring and let you know if we have any more issues
