EdinGer
Message 2 of 6
Router faulty ?
Hi, I keep getting loss of internet or low speeds (4-10mbps) and find restarting router restores speed to around 50-60mbps
Is this a sign of faulty router? It’s now every day this is happening.
thanks
5 REPLIES 5
EdinGer
Message 1 of 6
Router faulty ?
Hi, I keep getting loss of internet or low speeds (4-10mb) and find restarting router restores speed to around 50-60mb. Is this a sign of faulty router? It’s now every day this is happening.
thanks
Keith_Beddoe
Message 3 of 6
Re: Router faulty ?
@EdinGer
Is that just on wireless connected devices?
Which BT Home Hub do you have?
EdinGer
Message 4 of 6
Re: Router faulty ?
Yes on wireless when testing
EdinGer
Message 5 of 6
Re: Router faulty ?
Maybe BTHub6 ?
Keith_Beddoe
Message 6 of 6
Re: Router faulty ?
Then what is probably happening, is that the wireless channel that you are using at the time has become congested, and you need to use another channel.
Restarting the home hub would do that, but it would be better to log into the hub manager, and manually rescan for a new channel.
https://www.bt.com/help/broadband/getting-set-up/home-networks/a-wi-fi-home-network/what-is-the-smar...
Its a good idea on the HH6, to make sure smart setup is also turned off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
