Keith_Beddoe
Message 11 of 15
Re: Router goes blinking yellow EVERY 30 minutes
If its doing it almost exactly every 30 minutes, then that would suggest that there is something causing electrical interference, possible something within your house. I assume this happens all the time, day and night?
martha_cd94
Message 12 of 15
It was an average, but yeah, day and night. It's not exactly 30 mins. Could last as long as 2 hours with internet. Also there isn't anything else being used in an abnormal way other than regular laptops 😕
imjolly
Message 13 of 15
If hub has already been replaced and numerous engineer visits it certainly sounds like something in your home is causing interference.  do you have anything that would use internet like burglar alarm or something 'reporting in'
so far even with all the drops in connection your speed is still ok with no adverse effects
martha_cd94
Message 14 of 15
If it helps, these are the errors I get "WAN" "Error no carrier"3E9E7CF5-79B2-468E-B8E7-E519C80A30FE.png
RobbieMac
Moderator
Moderator
Message 15 of 15
Hi @martha_cd94
Welcome to the Community and thanks for your posts!
I'm sorry for the problems you're having with your broadband and for the time this has been going on.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
