lfclockers7
Newbie
Message 1 of 2
Router needs daily restart
No particulary problem with the connection when it's working fine. However, it seems that after a certain amount of time the connection drops to approx. 3-4mbps with internet browsing becoming an issue shared between 5 people.
Here is a variety of speed tests on the same connection showing before and afters of the router being restarted:
http://www.speedtest.net/results.php?sh=9a253827796992d835c3d768e359264a&ria=0
Anybody else have this problem / know how to resolve it? Is a new router required from BT?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Router needs daily restart
Hi Ifclockers7,
Welcome and thanks for posting!
Sorry for the problems you're having with your broadband speed.  Do you notice the speed slow down when using a wired or wireless connection?  If wireless, check out this link "How do I change the wireless channel on my BT Home Hub?"
Let me know how you get on.
Thanks,
Robbie
