jroadley
Message 1 of 4
Router reset daily, loss of internet access - usually same time each day.
Struggling with level 1 support so thought I'd take a go in here before contacting the CEO office.
Basically, we have BT Infinity - sync'd at 80/20 and works great.  However, everyday the HH6 resets, and we lose access to the internet - EVERYDAY
I've been asked to separate wifi networks, but it's nothing to do with that - the HH6 lights go orange and you can see in the HH6 logs, the uptime is back to 0.
Thinking it was the router, dugged out a ASUS VDSL router, TP-Link VDSL router and configured correctly to acess the BT VDSL network - and get the same restarts - usually same time each day.  Changed VDSL cables, turned off devices which could be messing with connection etc.  I've got £130 I'd even stuff in a Openreach engineer who can identify what the hell is going on with the line.
Please help me.
3 REPLIES 3
pippincp
Message 2 of 4
Re: Router reset daily, loss of internet access - usually same time each day.
The same time each day and different routers would tend to point a local cause (eg central heating)  and may be difficult to pin down.
jroadley
Message 3 of 4
We have had HIVE central heating for years, and never been a issue in the past. What is also weird, from the time it does it (This evening around
From the logs:
18:51:15, 22 May.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
18:51:10, 22 May.
BR_LAN:The LAN DHCPv6 Server is active
18:51:09, 22 May.
BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
18:51:09, 22 May.
ppp1:The DYN ROUTE [81.139.57.100/32 gw ] is deleted
18:51:09, 22 May.
ppp1:The DYN ROUTE [81.139.56.100/32 gw ] is deleted
18:51:09, 22 May.
BR_LAN:The LAN DHCPv6 Server is inactive
18:51:08, 22 May.
18:51:08, 22 May.
18:51:08, 22 May.
18:51:08, 22 May.
ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
18:51:08, 22 May.
18:51:08, 22 May.
imjolly
Message 4 of 4
If you are dropping connection about the same time daily the I agree with @pippincp  that it points to something switching on/off in your home or close by causing interference. Finding the cause could be difficult
