devoursoul
Newbie
Message 1 of 9
Routing Issue
Hi, since Sunday May 8th I have been having some problems with my internet. MY friends have said that my skyple calls have sounded robotic and in online games I have been lagging or in some cases just not been able to connect to them. I contacted Riot Games support to try and help find the source of the problem and help me fix it. After sending them several logs and different piece of information they have concluded that the problem is a routing issue. They said to contact my ISP to get this resolved.
If you require the logs I sent them I can give them to you I'm just a little hesitant to post them on here since they may contain my IP address.
Thanks, any helpw ould be appreciated.
8 REPLIES 8
Message 2 of 9
Re: Routing Issue
If they're traceroutes then they won't identify your IP address.
devoursoul
Newbie
Message 3 of 9
Re: Routing Issue
Here are two Traceroutes I did for them:Tracert 95.172.65.154.pngTracert 162.249.72.1.png
Distinguished Guru
Distinguished Guru
Message 4 of 9
Re: Routing Issue
2016-05-13 02_15_25-original (PNG Image, 1920 × 1080 pixels) - Scaled (66%).pngTypical. You're tracert's clearly show the problem starts at Riot games.
Message 5 of 9
Re: Routing Issue
Once the trace is beyond the last bt.net hop, the data is out onto the internet which is not part of BT's network. As a result, there's no fault with the BT network, and as such, BT have nothing to investigate.
smf22
Recognised Expert
Message 6 of 9
Re: Routing Issue
I think it depends which traceroute you look at.
Agreed that the first one looks very poor at the ae-32 hop with response times up to 841ms. That said, the second trace shows response times of over 200ms to the Home Hub.
Are you doing this test over a Wifi connection?
Regards
devoursoul
Newbie
Message 7 of 9
Re: Routing Issue
Yes it is a Wifi connection. Never had problems with it before. Also the problem is affecting my Skype aswell, friends can't undstand what I am saying since it is so borken up.
Message 8 of 9
Re: Routing Issue
Try it with a wired connection. Wouldn't be the first time we've seen it work fine previously on wireless then problems all of a sudden.
smf22
Recognised Expert
Message 9 of 9
Re: Routing Issue
Agreed that wired is best, and that it'll also prove the point.
As Webby points out, wireless can change all of a sudden.... interference from other WiFi, microwaves, bluetooth etc. For WiFi you could install a program called inSSIDer to check what other WiFi there is around you and whether there's any interference from them using the same channels.
Regards
