davehugh
Message 1 of 2
Routing
Wondered if anyone could help.  I am having some issues when playing call of duty on line.  At quiet times everything works well and I get paired up with people from the uk and the game runs well.  At peak times it is completely different and I get paired up with people from other countries and the game gets really laggy.  I hapened to run a traceroute at peak time to various uk websites including my own IP and noticed that I seem to be routed through Germany?  Wondered if this was related?
1   ***
2hos-tr4.juniper2.rz13.hetzner.de213.239.224.97 0.482 ms0.491 ms
 hos-tr3.juniper2.rz13.hetzner.de213.239.224.65 1.085 ms
3core22.hetzner.de213.239.245.121 0.774 ms1.339 ms0.764 ms
4core4.hetzner.de213.239.245.14 6.165 ms6.156 ms
 core1.hetzner.de213.239.245.177 5.062 ms
5juniper4.ffm.hetzner.de213.239.245.10 7.313 ms6.154 ms6.074 ms
6et-0-3-0-710.fra20.core-backbone.com80.255.15.121 7.748 ms7.776 ms6.642 ms
7166-49-154-65.eu.bt.net166.49.154.65 6.356 ms6.691 ms6.583 ms
8t2c3-xe-2-2-2-0.uk-lon1.eu.bt.net166.49.208.116 18.370 ms
 t2c3-xe-2-2-1-0.uk-lon1.eu.bt.net166.49.208.114 19.919 ms
 t2c3-xe-2-2-3-0.uk-lon1.eu.bt.net166.49.208.118 19.925 ms
9166-49-211-239.eu.bt.net166.49.211.239 20.916 ms
 166-49-211-241.eu.bt.net166.49.211.241 22.400 ms21.273 ms
10acc2-10GigE-0-5-0-4.l-far.21cn-ipp.bt.net109.159.254.232 22.480 ms
 core1-te0-3-0-10.ealing.ukcore.bt.net109.159.254.103 21.396 ms
 core1-te0-3-0-4.ealing.ukcore.bt.net62.172.102.18 21.389 ms
11acc1-10GigE-2-0-0.sf.21cn-ipp.bt.net109.159.251.146 27.501 ms
 acc1-10GigE-0-3-3.sf.21cn-ipp.bt.net109.159.251.182 27.102 ms
 acc1-10GigE-9-0-0.sf.21cn-ipp.bt.net109.159.251.20 48.172 ms
12acc1-10GigE-0-2-0.sf.21cn-ipp.bt.net109.159.251.66 26.814 ms
 acc1-10GigE-1-2-0.sf.21cn-ipp.bt.net109.159.251.70 28.561 ms
   gb
13   ***
14   ***
15   ***
 Appreciate your thoughts.
1 REPLY 1
Aratark
Message 2 of 2
Re: Routing
I'm going to guess you ran that traceroute on ping.eu. They are based in Germany I believe, that is why the initial part runs through German hops. If you are trying to test your connection, you would need to run the traceroute through command prompt/terminal.
