clansman007
Message 21 of 47
Re: SNR Margin on VDSL compared to SNR MArgin on ADSL
Hi SeanD
Engineer has been. A really helpful fellow who saw errors on the line. Voice side was checking out OK. Checkeed the wiring of the master socket as well.
He went to the cabinet and moved the port I was in, is this a port in the Fibre cabinet that he would be referring to.
Broadband is back up and he has called to say he see's no errors anymore.
He says that there will be a couple of reset's to happen - would that be the IP Profile reset and a DLM reset he is referring to.
I am monitoring the SNR margins meantime using Router Stats Lite for the HH5, it was 6.2 when it came back but I can already see it dropping - currently 5.6
Your thoughts would be much appreciated
Sage
Sage
Message 22 of 47
You are correct in what he was referring to.
Monitor your SNR over the next few days and keep us updated.
clansman007
Message 23 of 47
Thanks pippincp
I will monitor it and come back with the results in a few days
Much appreciated
clansman007
Message 24 of 47
Hi All.
Thats about 48 hours since the engineers visit. ADSL hasnt dropped as of yet. SNR seems to be sitting at 5.5 pretty well most of the time. I have copied in some extracts of the logs.
Date                    Time        SNRUp   SNRD  Up        Down    MaxU     MaxD
Wed 02 Apr 2014  18:00:01,      6.2,     6.3,   13683,   45238,   13811,   44582
Wed 02 Apr 2014  18:00:16,      6.2,     6.3,   13683,   45238,   13805,   44669
Wed 02 Apr 2014  18:00:34,      6.2,     5.6,   13683,   45238,   13811,   42036
Wed 02 Apr 2014  18:00:46,      6.2,     6.0,   13683,   45238,   13805,   42661
Wed 02 Apr 2014  18:01:01,      6.2,     6.0,   13683,   45238,   13805,   42574
Wed 02 Apr 2014  18:01:16,      6.1,     6.2,   13683,   45238,   13779,   43705
Wed 02 Apr 2014  18:01:32,      6.2,     6.2,   13683,   45238,   13818,   43570
Wed 02 Apr 2014  18:01:47,      6.1,     6.1,   13683,   45238,   13792,   42661
Wed 02 Apr 2014  18:02:02,      6.1,     6.1,   13683,   45238,   13795,   42940
Thu 03 Apr 2014  00:00:01,      6.2,     5.5,   13683,   45238,   13811,   40339
Thu 03 Apr 2014  00:00:31,      6.2,     5.5,   13683,   45238,   13811,   40323
Thu 03 Apr 2014  00:01:01,      6.2,     5.5,   13683,   45238,   13795,   40470
Thu 03 Apr 2014  00:01:31,      6.2,     5.5,   13683,   45238,   13831,   40191
Thu 03 Apr 2014  00:02:01,      6.2,     5.5,   13683,   45238,   13811,   40299
Thu 03 Apr 2014  00:02:31,      6.2,     5.5,   13683,   45238,   13818,   40394
Thu 03 Apr 2014  06:00:12,      6.2,     5.6,   13683,   45238,   13864,   39630
Thu 03 Apr 2014  06:00:42,      6.2,     5.6,   13683,   45238,   13847,   39697
Thu 03 Apr 2014  06:01:12,      6.2,     5.6,   13683,   45238,   13838,   39622
Thu 03 Apr 2014  06:01:42,      6.2,     5.6,   13683,   45238,   13844,   39626
Thu 03 Apr 2014  06:02:12,      6.2,     5.6,   13683,   45238,   13883,   39590
Thu 03 Apr 2014  06:02:42,      6.2,     5.6,   13683,   45238,   13857,   39562
Thu 03 Apr 2014  12:00:01,      6.2,     5.5,   13683,   45238,   13818,   39518
Thu 03 Apr 2014  12:00:16,      6.2,     5.6,   13683,   45238,   13818,   39606
Thu 03 Apr 2014  12:00:31,      6.2,     5.6,   13683,   45238,   13821,   39546
Thu 03 Apr 2014  12:00:46,      6.1,     5.6,   13683,   45238,   13782,   39562
Thu 03 Apr 2014  12:01:01,      6.2,     5.6,   13683,   45238,   13795,   39586
Thu 03 Apr 2014  12:01:16,      6.2,     5.5,   13683,   45238,   13805,   39490
Thu 03 Apr 2014  18:00:11,      6.2,     5.5,   13683,   45238,   13821,   39032
Thu 03 Apr 2014  18:00:26,      6.2,     5.5,   13683,   45238,   13795,   39072
Thu 03 Apr 2014  18:00:41,      6.2,     5.6,   13683,   45238,   13815,   39143
Thu 03 Apr 2014  18:00:56,      6.2,     5.6,   13683,   45238,   13798,   39116
Thu 03 Apr 2014  18:01:11,      6.2,     5.6,   13683,   45238,   13821,   39128
Thu 03 Apr 2014  18:01:26,      6.2,     5.6,   13683,   45238,   13795,   39088
Fri 04 Apr 2014  00:00:11,      6.2,     5.6,   13683,   45238,   13828,   38881
Fri 04 Apr 2014  00:00:41,      6.2,     5.6,   13683,   45238,   13824,   38972
Fri 04 Apr 2014  00:01:11,      6.2,     5.6,   13683,   45238,   13808,   38976
Fri 04 Apr 2014  00:01:41,      6.2,     5.6,   13683,   45238,   13811,   39036
Fri 04 Apr 2014  00:02:11,      6.2,     5.6,   13683,   45238,   13805,   39163
Fri 04 Apr 2014  00:02:41,      6.2,     5.6,   13683,   45238,   13815,   39179
Fri 04 Apr 2014  11:24:31,      6.2,     5.6,   13683,   45238,   13808,   37893
Fri 04 Apr 2014  11:25:01,      6.2,     5.5,   13683,   45238,   13802,   37809
Fri 04 Apr 2014  11:25:31,      6.2,     5.5,   13683,   45238,   13851,   37805
Fri 04 Apr 2014  11:26:01,      6.2,     5.5,   13683,   45238,   13818,   37829
Fri 04 Apr 2014  11:26:31,      6.2,     5.5,   13683,   45238,   13808,   37801
Fri 04 Apr 2014  11:27:01,      6.2,     5.5,   13683,   45238,   13815,   37841
From the logs, the Down SNR seems to be sitting at around 5.5 most of the time - is this OK. Also the last 2 columns are the max Upload and Max Download. The Max Download is dropping from when it established a connection - is this something to be concerned with
Thanks in advance for any info and advice that you have
clansman007
Message 25 of 47
Well I spoke to soon, VDSL dropped this morning at about 5.30am and re-connected at a higher speed but the SNR is lower. Unfortunately my Laptop monitoring the Link died as well so I dont know what the stats at the time of diconnect are. I have moved to a more stable PC now
Sat 05 Apr 2014  12:35:00,      6.1,     5.0,   12732,   47965,   12833,   39790
Sat 05 Apr 2014  12:35:10,      6.1,     5.0,   12732,   47965,   12813,   39726
Sat 05 Apr 2014  12:35:20,      6.1,     5.0,   12732,   47965,   12846,   39738
Sat 05 Apr 2014  12:35:30,      6.1,     5.0,   12732,   47965,   12826,   39746
Sat 05 Apr 2014  12:35:40,      6.1,     5.0,   12732,   47965,   12839,   39762
Sat 05 Apr 2014  12:35:50,      6.1,     5.0,   12732,   47965,   12849,   39762
Sat 05 Apr 2014  12:36:00,      6.1,     5.0,   12732,   47965,   12849,   39750
Any ideas guys Smiley Frustrated
Sage
Sage
Message 26 of 47
Your down SNR is still below target and is the most likely cause of your problem. From your logs things were looking good until it dropped below 6.0
Perhaps request a BB Boost engineer out to sort it?
clansman007
Message 27 of 47
Thanks for the info
Would I have to go thru the whole support story again
What exactly does a Broadband Boost entail - is it another engineer visit
Sorry, for asking but I haven't heard of a BB boost before so I apologise for my inexperience with the term
clansman007
Message 28 of 47
I should add is it an engineer visit to home or exchange
Sage
Sage
Message 29 of 47
Yes it would entail an engineer visit. There's a problem somewhere that needs to be tracked down IMHO.
I'll ask a mod to drop in again and deal with him/her.
clansman007
Message 30 of 47
Thanks again pippincp - if I was in your town I would buy you a pint or a coffee, whatever your choice was for your help 🙂
I have included my logs from  19:15 tomight when it was pretty erratic although didnt drop out. It does seem to be not behaving
Sat 05 Apr 2014  19:15:52,      6.0,     5.2,   12732,   47965,   12745,   40308
Sat 05 Apr 2014  19:16:02,      6.0,     5.2,   12732,   47965,   12755,   40384
Sat 05 Apr 2014  19:16:12,      6.0,     5.3,   12732,   47965,   12741,   40695
Sat 05 Apr 2014  19:16:22,      6.0,     4.9,   12732,   47965,   12768,   38898
Sat 05 Apr 2014  19:16:33,      6.0,     4.5,   12732,   47965,   12758,   37818
Sat 05 Apr 2014  19:16:42,      6.0,     4.9,   12732,   47965,   12774,   39320
Sat 05 Apr 2014  19:16:52,      6.0,     5.0,   12732,   47965,   12768,   39201
Sat 05 Apr 2014  19:17:02,      6.0,     5.1,   12732,   47965,   12741,   39965
Sat 05 Apr 2014  19:17:12,      6.0,     5.2,   12732,   47965,   12745,   40236
Sat 05 Apr 2014  19:17:22,      6.0,     4.9,   12732,   47965,   12774,   39065
Sat 05 Apr 2014  19:17:33,      6.0,     4.5,   12732,   47965,   12761,   38153
Sat 05 Apr 2014  19:17:42,      6.0,     4.7,   12732,   47965,   12738,   39033
Sat 05 Apr 2014  19:17:52,      6.0,     5.2,   12732,   47965,   12764,   40372
Sat 05 Apr 2014  19:18:02,      6.0,     5.0,   12732,   47965,   12768,   39635
Sat 05 Apr 2014  19:18:12,      6.0,     5.0,   12732,   47965,   12751,   40045
Sat 05 Apr 2014  19:18:22,      6.0,     4.4,   12732,   47965,   12761,   38201
Sat 05 Apr 2014  19:18:33,      6.0,     5.1,   12732,   47965,   12755,   39639
Sat 05 Apr 2014  19:18:42,      6.0,     4.4,   12732,   47965,   12751,   37942
Sat 05 Apr 2014  19:18:52,      6.0,     4.7,   12732,   47965,   12764,   38722
Thanks again
