clansman007
Message 41 of 47
Re: SNR Margin on VDSL compared to SNR MArgin on ADSL
Hi there
Was down twice this morning with 2 (1109722.110000) PPP LCP Send Termination Request [User request] within 5 mins
Although down may be the wrong description as the VDSL synch speed stayed the same and no drop of SNR, Attenuation etc etc
SteveBB
Message 42 of 47
Can I ask which program you're using for the graph?
Message 43 of 47
@SteveBBThats the one downside to the TP-Link, you can't access the stats to graph with any program.
clansman007
Message 44 of 47
I used Router Stats lite for Home Hub 5
clansman007
Message 45 of 47
Gigabit
Message 46 of 47
I think you might have an HR fault.
It would be good if you could show us your Hlog and QLN graphs but I believe the Home Hub doesn't provide any data to output said graphs.
YannishS
Newbie
Message 47 of 47
Hi
Can anyone give the reference values for Upstream SNR Margin, Downstream SNR Margin, Upstream Signal Attenuation and Downstream Signal Attenuation on a VDSL Line so that same can be cross verified.
Thank you.
Regards,
