Sage
Sage
Message 31 of 47
Re: SNR Margin on VDSL compared to SNR MArgin on ADSL
It doesn't look good, wait for the mod and use the contact link they give you. It may take up to 5 days for them to reply to you but well worth the wait.
clansman007
Message 32 of 47
Here is the drop at 2am this morning which I assume may be DLM related, SNR still erratic
clansman007
Message 33 of 47
clansman007
Message 34 of 47
No worries pippincp, I look forward to it 🙂 and will continue to monitor so I have the info if required
Moderator
Moderator
Message 35 of 47
Hi Clansman007,
I can take a look at your connection. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
clansman007
Message 36 of 47
Thanks PaddyB
contacted via the link on your profile as requested, any other info required then let me know
Much appreciated
clansman007
Message 37 of 47
Was downloading this morning. My very erratic SNR dropped significantly while downloading - see pic - is this normal behaviour or another indication that there may be an issue and then started steadily risingCropperCapture[13].jpg
clansman007
Message 38 of 47
Just noticed that although my VDSL dropped, I do not see this reflected in my software monitoring tool. Sych Speed never dropped. In the HH% log, I see this
(983311.640000) PPP LCP Send Termination Request [User request]
Not a full drop out as such as the SNR, Max Rate or Attenuation show no change and there are a few
PPP LCP Send Configuration Request
PPP LCP Receive Configuration ACK
Starting CHAP authentication with peer
All in the space of about 4 seconds
I take it there has been a re-authentication going on
Is this normal behaviour?
Sage
Sage
Message 39 of 47
According to the mods this is indicative of a line problem.
clansman007
Message 40 of 47
Thanks pippincp
Regarding when you asked a mod to assist, I filled the form in as per this request - what is the process now.
Please dont think I am inpatient, its more that I know I havent missed anything and they think its all ok now orr that I aint bothered
