mrt1981
Message 1 of 9
Serious frustration at slow speeds and frequent disconnects
So I've posted before about disconencts and slow speeds and had some great help from @PaddyB , but this is getting ridiculous. It seems like every couple of weeks now I'll have a day or two where my router constantly disconnects and my speed drops to a fraction of what it should be. Always in the evenings - router resets, flashing pink, flashing orange, solid orange, blue for 5 minutes, flashing pink, flashing orange... etc. When the connection finally comes back stable I'll be getting 3-4mbps instead of the usual 40+.
I've used the diagnostics in the BT app numerous times and had it come up with phoneline faults, broadband faults, telling me they need to send an engineer, and telling me they can't find any problem. We've had numerous faults raised and apparently fixed. We've had engineers go out to the cabinet and find nothing wrong, I believe we've had our port switched at the cabinet too? We've had an engineer come to the house and check the wiring and replace the microfilter and phone cable and tell us our speeds should increase by 7-10% (and we did to be fair see a small increase for a while). We've even had an engineer come to the house in person to tell us the fault was fixed because they tried calling our landline to tell us but we don't have a phone plugged in (not sure why they couldn't call my mobile like they normally do?). The last fault a couple of weeks ago they sent me a minihub as I'd upgraded to BT Plus but that was pointless because the connection was back by the time it arrived, and it was switched off again the night before the most recent issues started. And again, the other night the connection went haywire and although it now appears stable again, it's maxing out at about 8mbps.
It seems this is getting more frequent recently, and I've seen a number of tweets etc complaining about the same issues but the service status is always "Everything's OK", and I'm getting more and more frustrated.
Quiet line test is silent, no phones plugged in anywhere, router plugged in to master socket. Router stats etc below:
Product name:
BT Hub 6A
Serial number:
+084316+NQ64506849
Firmware version:
SG4B1000E01E
Firmware updated:
06-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
1 Days, 2 Hours 27 Minutes 24 Seconds
Data rate:
9.38 Mbps / 9.61 Mbps
Maximum data rate:
12629 / 29322
Noise margin:
10.4 dB / 20.8 dB
Line attenuation:
22.8 dB
Signal attenuation:
0 dB / 22.8 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
592 MB Uploaded / 8649 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-9GW7
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-9GW7
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:60:C7:B7
Software variant:
Boot loader:
7.33.
Some of the Logs for WAN/PPP events on the night of the last disconnects:
22:07:34, 13 Aug.,:WAN: SENSING AUTO VDSL
22:07:33, 13 Aug.,ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
22:07:33, 13 Aug.,ppp:PPP: IPCP_NAK
22:07:33, 13 Aug.,ppp:PPP: CHAP_SUCCESS
22:07:33, 13 Aug.,ppp:PPP: CHAP_RESPONSE
22:07:33, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
22:07:33, 13 Aug.,ppp:PPP: LCP_REQUEST
22:07:32, 13 Aug.,:PPPoE error: timeout
22:07:16, 13 Aug.,:PPPoE error: timeout
22:07:08, 13 Aug.,:PPPoE error: timeout
22:07:04, 13 Aug.,:PPPoE error: timeout
22:06:58, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
22:06:58, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
22:06:58, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
22:06:57, 13 Aug.,dsl:VDSL link Up: Down Rate=9075Kbps, Up Rate=9379Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
22:06:34, 13 Aug.,:VLAN VLAN_DATA disconnected
22:06:32, 13 Aug.,dsl:VDSL Link Down: duration was 82 seconds
22:05:43, 13 Aug.,ppp:PPP: CHAP_RESPONSE
22:05:43, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
22:05:43, 13 Aug.,ppp:PPP: LCP_REQUEST
22:05:43, 13 Aug.,:PPPoE error: timeout
22:05:27, 13 Aug.,:PPPoE error: timeout
22:05:19, 13 Aug.,:PPPoE error: timeout
22:05:15, 13 Aug.,:PPPoE error: timeout
22:05:11, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
22:05:10, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
22:05:10, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
22:05:10, 13 Aug.,dsl:VDSL link Up: Down Rate=18092Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
22:04:49, 13 Aug.,:VLAN VLAN_DATA disconnected
22:04:47, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
22:04:45, 13 Aug.,dsl:VDSL Link Down: duration was 555 seconds
21:56:04, 13 Aug.,:WAN: SENSING AUTO VDSL
21:56:04, 13 Aug.,ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
21:56:03, 13 Aug.,ppp1:PPP: PPP INFO
21:56:03, 13 Aug.,ppp:PPP: IPCP_NAK
21:56:03, 13 Aug.,ppp:PPP: CHAP_SUCCESS
21:56:03, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:56:03, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:56:03, 13 Aug.,ppp:PPP: LCP_REQUEST
21:56:03, 13 Aug.,:PPPoE error: timeout
21:55:47, 13 Aug.,:PPPoE error: timeout
21:55:39, 13 Aug.,:PPPoE error: timeout
21:55:34, 13 Aug.,:PPPoE error: timeout
21:55:30, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:55:30, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:55:30, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:55:30, 13 Aug.,dsl:VDSL link Up: Down Rate=17493Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:55:08, 13 Aug.,:VLAN VLAN_DATA disconnected
21:55:07, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:55:04, 13 Aug.,dsl:VDSL Link Down: duration was 527 seconds
21:47:26, 13 Aug.,:WAN: SENSING AUTO VDSL
21:47:25, 13 Aug.,ppp1:PPP: PPP INFO 81.139.57.100,81.139.56.100
21:47:25, 13 Aug.,ppp:PPP: IPCP_NAK
21:47:25, 13 Aug.,ppp:PPP: CHAP_SUCCESS
21:47:24, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:47:24, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:47:24, 13 Aug.,ppp:PPP: LCP_REQUEST
21:46:52, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:46:52, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:46:52, 13 Aug.,ppp:PPP: LCP_REQUEST
21:46:52, 13 Aug.,:PPPoE error: timeout
21:46:36, 13 Aug.,:PPPoE error: timeout
21:46:28, 13 Aug.,:PPPoE error: timeout
21:46:24, 13 Aug.,:PPPoE error: timeout
21:46:18, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:46:17, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:46:17, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:46:17, 13 Aug.,dsl:VDSL link Up: Down Rate=20628Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:45:35, 13 Aug.,:VLAN VLAN_DATA disconnected
21:45:33, 13 Aug.,dsl:VDSL Link Down: duration was 21 seconds
21:45:29, 13 Aug.,:PPPoE error: timeout
21:45:21, 13 Aug.,:PPPoE error: timeout
21:45:16, 13 Aug.,:PPPoE error: timeout
21:45:12, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:45:12, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:45:12, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:45:12, 13 Aug.,dsl:VDSL link Up: Down Rate=19326Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:44:50, 13 Aug.,:VLAN VLAN_DATA disconnected
21:44:49, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:44:48, 13 Aug.,ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:44:46, 13 Aug.,dsl:VDSL Link Down: duration was 77 seconds
21:44:03, 13 Aug.,:WAN: SENSING AUTO VDSL
21:44:02, 13 Aug.,ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
21:44:02, 13 Aug.,ppp:PPP: IPCP_NAK
21:44:02, 13 Aug.,ppp:PPP: CHAP_SUCCESS
21:44:02, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:44:02, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:44:02, 13 Aug.,ppp:PPP: LCP_REQUEST
21:44:02, 13 Aug.,:PPPoE error: timeout
21:43:46, 13 Aug.,:PPPoE error: timeout
21:43:37, 13 Aug.,:PPPoE error: timeout
21:43:33, 13 Aug.,:PPPoE error: timeout
21:43:29, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:43:29, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:43:29, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:43:29, 13 Aug.,dsl:VDSL link Up: Down Rate=36255Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:43:07, 13 Aug.,:VLAN VLAN_DATA disconnected
21:43:06, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:43:06, 13 Aug.,ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:43:03, 13 Aug.,dsl:VDSL Link Down: duration was 70 seconds
21:42:33, 13 Aug.,:WAN: SENSING AUTO VDSL
21:42:30, 13 Aug.,ppp1:PPP: PPP INFO 81.139.57.100,81.139.56.100
21:42:30, 13 Aug.,ppp:PPP: IPCP_NAK
21:42:30, 13 Aug.,ppp:PPP: CHAP_SUCCESS
21:42:30, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:42:30, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:42:30, 13 Aug.,ppp:PPP: LCP_REQUEST
21:42:28, 13 Aug.,:PPPoE error: timeout
21:42:12, 13 Aug.,:PPPoE error: timeout
21:42:04, 13 Aug.,:PPPoE error: timeout
21:42:00, 13 Aug.,:PPPoE error: timeout
21:41:54, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:41:53, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:41:53, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:41:53, 13 Aug.,dsl:VDSL link Up: Down Rate=46336Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:41:30, 13 Aug.,:VLAN VLAN_DATA disconnected
21:41:27, 13 Aug.,dsl:VDSL Link Down: duration was 21 seconds
21:41:25, 13 Aug.,:PPPoE error: timeout
21:41:17, 13 Aug.,:PPPoE error: timeout
21:41:13, 13 Aug.,:PPPoE error: timeout
21:41:07, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:41:06, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:41:06, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:41:06, 13 Aug.,dsl:VDSL link Up: Down Rate=20982Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:40:35, 13 Aug.,:VLAN VLAN_DATA disconnected
21:40:33, 13 Aug.,dsl:VDSL Link Down: duration was 31 seconds
21:40:21, 13 Aug.,:PPPoE error: timeout
21:40:13, 13 Aug.,:PPPoE error: timeout
21:40:09, 13 Aug.,:PPPoE error: timeout
21:40:02, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:40:02, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:40:02, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:40:02, 13 Aug.,dsl:VDSL link Up: Down Rate=48195Kbps, Up Rate=9326Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:39:32, 13 Aug.,:VLAN VLAN_DATA disconnected
21:39:31, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:39:31, 13 Aug.,ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:39:28, 13 Aug.,dsl:VDSL Link Down: duration was 178 seconds
21:37:07, 13 Aug.,:WAN: SENSING AUTO VDSL
21:37:06, 13 Aug.,ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
21:37:05, 13 Aug.,ppp:PPP: IPCP_NAK
21:37:05, 13 Aug.,ppp:PPP: CHAP_SUCCESS
21:37:05, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:37:05, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:37:05, 13 Aug.,ppp:PPP: LCP_REQUEST
21:37:05, 13 Aug.,:PPPoE error: timeout
21:36:49, 13 Aug.,:PPPoE error: timeout
21:36:41, 13 Aug.,:PPPoE error: timeout
21:36:37, 13 Aug.,:PPPoE error: timeout
21:36:30, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:36:30, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:36:30, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:36:30, 13 Aug.,dsl:VDSL link Up: Down Rate=53332Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:35:34, 13 Aug.,:VLAN VLAN_DATA disconnected
21:35:33, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:35:32, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:35:30, 13 Aug.,dsl:VDSL Link Down: duration was 325 seconds
21:30:40, 13 Aug.,:WAN: SENSING AUTO VDSL
21:30:39, 13 Aug.,ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
21:30:39, 13 Aug.,ppp:PPP: IPCP_NAK
21:30:39, 13 Aug.,ppp:PPP: CHAP_SUCCESS
21:30:39, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:30:39, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:30:39, 13 Aug.,ppp:PPP: LCP_REQUEST
21:30:38, 13 Aug.,:PPPoE error: timeout
21:30:22, 13 Aug.,:PPPoE error: timeout
21:30:14, 13 Aug.,:PPPoE error: timeout
21:30:10, 13 Aug.,:PPPoE error: timeout
21:30:06, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:30:06, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:30:06, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:30:05, 13 Aug.,dsl:VDSL link Up: Down Rate=34959Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:29:44, 13 Aug.,:VLAN VLAN_DATA disconnected
21:29:42, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:29:40, 13 Aug.,dsl:VDSL Link Down: duration was 83 seconds
21:28:54, 13 Aug.,:WAN: SENSING AUTO VDSL
21:28:53, 13 Aug.,ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
21:28:53, 13 Aug.,ppp:PPP: IPCP_NAK
21:28:53, 13 Aug.,ppp:PPP: CHAP_SUCCESS
21:28:53, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:28:53, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:28:53, 13 Aug.,ppp:PPP: LCP_REQUEST
21:28:52, 13 Aug.,:PPPoE error: timeout
21:28:36, 13 Aug.,:PPPoE error: timeout
21:28:28, 13 Aug.,:PPPoE error: timeout
21:28:24, 13 Aug.,:PPPoE error: timeout
21:28:18, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:28:17, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:28:17, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:28:17, 13 Aug.,dsl:VDSL link Up: Down Rate=39796Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:27:53, 13 Aug.,:VLAN VLAN_DATA disconnected
21:27:51, 13 Aug.,dsl:VDSL Link Down: duration was 31 seconds
21:27:39, 13 Aug.,:PPPoE error: timeout
21:27:31, 13 Aug.,:PPPoE error: timeout
21:27:27, 13 Aug.,:PPPoE error: timeout
21:27:20, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:27:20, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:27:20, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:27:20, 13 Aug.,dsl:VDSL link Up: Down Rate=52891Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:26:58, 13 Aug.,:VLAN VLAN_DATA disconnected
21:26:56, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:26:54, 13 Aug.,dsl:VDSL Link Down: duration was 283 seconds
21:22:46, 13 Aug.,:WAN: SENSING AUTO VDSL
21:22:45, 13 Aug.,ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
21:22:45, 13 Aug.,ppp:PPP: IPCP_NAK
21:22:45, 13 Aug.,ppp:PPP: CHAP_SUCCESS
21:22:45, 13 Aug.,ppp:PPP: CHAP_RESPONSE
21:22:45, 13 Aug.,ppp:PPP: LCP_GOOD_ACK
21:22:45, 13 Aug.,ppp:PPP: LCP_REQUEST
21:22:44, 13 Aug.,:PPPoE error: timeout
21:22:28, 13 Aug.,:PPPoE error: timeout
21:22:20, 13 Aug.,:PPPoE error: timeout
21:22:16, 13 Aug.,:PPPoE error: timeout
21:22:12, 13 Aug.,ptm0.101:VLAN VLAN_DATA connected
21:22:12, 13 Aug.,:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:22:12, 13 Aug.,:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:22:11, 13 Aug.,dsl:VDSL link Up: Down Rate=34185Kbps, Up Rate=9999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=3.00dB
21:21:50, 13 Aug.,:VLAN VLAN_DATA disconnected
21:21:49, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:21:48, 13 Aug.,:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:21:46, 13 Aug.,dsl:VDSL Link Down: duration was 476035 seconds
8 REPLIES 8
Message 2 of 9
Re: Serious frustration at slow speeds and frequent disconnects
did you try quiet line test on night of13th when all the drops in connection were happening to see if there was noise on the line?  there was numerous resets in short space of time with connection speeds down/up all over the place
are you using test socket with filter to eliminate your internal wiring and faceplate as causing the problem
even though you don't use landline have you checked than when connected to test socket there is no dial tone at any extension socket?
mrt1981
Message 3 of 9
I didn't try the quiet line test on the 13th no, it was done last night. The wiring was all checked by an engineer about a month ago and he couldn't find any issues so I'd be surprised if that was it, but I can check again later, same for the extensions
Message 4 of 9
if drops happen again like 13th then that would be ideal time to check for line noise
mrt1981
Message 5 of 9
Yeah fair point hehe.  One of those things that I forgot about in my frustration and in amidst running diagnostics checks.
I've double checked wiring and made sure all the extensions are dead when using the test socket. Currently back up to a more respectable 47mbps connected through the faceplate
Sage
Sage
Message 6 of 9
Could you repost the connection stats?
mrt1981
Message 7 of 9
Product name:
BT Hub 6A
Serial number:
+084316+NQ64506849
Firmware version:
SG4B1000E01E
Firmware updated:
06-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 0 Hours 51 Minutes 1 Seconds
Data rate:
10.00 Mbps / 52.28 Mbps
Maximum data rate:
12795 / 53380
Noise margin:
8.9 dB / 4.2 dB
Line attenuation:
19.7 dB
Signal attenuation:
0 dB / 19.7 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
17 MB Uploaded / 2681 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-9GW7
Smart (Channel 6)
BTHub6-9GW7
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:60:C7:B7
Software variant:
Boot loader:
7.33.1
Message 8 of 9
You have 52mb connection speed which is virtually at attainable so looking k apart from very short connection time. Just now need to see if connection will remain stable
mrt1981
Message 9 of 9
Yeah the short connection time is from me checking the extension sockets. Fingers crossed...
