Sage
Sage
Message 21 of 28
Re: Sharp drop of speed on broadband that hasn’t corrected itself.
You max speed is below the handback threshold so yes, you can request it is investigated.
Before you do though I would suggest you connect to the test socket with a filter, conduct a quiet line test 17070 option 2 and make sure any extentions are not working to rule out anything within your property which would be chargeable.
Seaweed
Message 22 of 28
By means of an update i have run all the tests as outlined, but still have slow speeds. is there a mod here that can provide assistance in getting this fixed?
Here are my latest stats from my HH6
This is a list of your BT Business Smart Hub settings and current statistics.
Product name:
Business Smart Hub
Serial number:
removed
Firmware version:
SG4B1B0092B4
Firmware updated:
09-May-2019
Board version:
1.0
Gui version:
1.117.0
DSL uptime:
12 Days, 1 Hours 6 Minutes 27 Seconds
Data rate:
18.30 Mbps / 65.82 Mbps
Maximum data rate:
18300 / 66305
Noise margin:
5.9 dB / 5.2 dB
Line attenuation:
0 dB / 14.3 dB
Signal attenuation:
0 dB / 14.3 dB
VLAN id:
101
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
21 GB Uploaded / 76 GB Downloaded
Broadband username:
green-light@service.btclick.com
Public wi-fi
Not active
2.4 GHz wireless network name:
Cff2.4
2.4 GHz wireless channel:
Channel 6
5 GHz wireless network name:
Cff5
5 GHz wireless channel:
Channel 36
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
58:90:43:32xxx87
Software variant:
Boot loader:
8.4.0
many thanks
Moderator
Moderator
Message 23 of 28
Hi @Seaweed,
Welcome back to the Community.
Sorry to hear that you are having problems with your connection again.
I noticed that your hub stats are showing a"Business Smart Hub" are you a BT Business or Residential customer?
Matt
Community ModeratorMatt
Show your appreciation!
Kudos”Kudos”
Seaweed
Message 24 of 28
Hello.
Im a business customer.
many thanks
Message 25 of 28
@Seaweed
You are posting on the wrong forum. The moderators on this residential forum cannot help with business customers.
There is a separate forum for BT Business users and the moderators there, may be able to help.
Forum is at http://business.forums.bt.com/
Moderator
Moderator
Message 26 of 28
Thanks for getting back to me so quickly @Seaweed
We only have access to BT Residential Accounts so we wouldn't be able to help you with this one.
BT have a Business Forum who may be able to help you.
Matt
Kudos”Kudos”
pompey1898
Expert
Message 27 of 28
Hi @Seaweed
Amazing that it took 9 months, and many posts, to find that out !
Sage
Sage
Message 28 of 28
Amazing the OP never mentioned it for 9 months.
