Venomx
Expert
Message 1 of 4
Should I Enable 5G band ?
Would enabling 5G band help reduce any congestion or should I just keep 2.4ghz activated only ?
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: Should I Enable 5G band ?
@Venomx the 5Ghz channel is less prone to congestion from other wifi signals but it doesn't have as good a range. If you're having issues you could always turn it off again.
Venomx
Expert
Message 3 of 4
Was having problems with notifications coming through on my phone in the evenings. Enabled 5Ghz again and selected auto select and seems to have fixed it.
If not i'll get a TP Link router or something similar
SaiBork
Message 4 of 4
5G will possibly allow faster speeds, but has less range. Having a smaller range is also one of the reasons it will be less congested as other signals are less likely to reach far enough to interfere with yours.
