Message 1 of 3
Should my dsl and network uptime reset itself
Pretty much says it all in the description, it’s been fine for 4 days without a single drop. I recently upgraded to fibre 2, will it disconnect randomly during the first ten days and then stabilise itself OR am I looking at random dropouts for no reason
2 REPLIES 2
Message 2 of 3
Re: Should my dsl and network uptime reset itself
did you check to see if any noise on quiet line test that could be causing your drop in connection?
Message 3 of 3
Yeah checked it and 0 noise. I checked the logs and can’t make heads or tails of it
