Message 1 of 2
Signal attenuation showing a minus value?
Could anyone advise what a minus value of -107.3 indicates on the Signal attenuation?
I recently had a BT Openreach engineer out who was brilliant, he spent several hours fixing a fault on my connection due to slow speeds and the line now appears stable compared to before albeit the DLM is doing its thing ATM. The connection slowed a little since day 1 and low-level interleaving been applied to the line.
This line has always been interleaved due to aluminum being in the wires at some points between my house and the street cabinet which they will not replace etc.
Any advice regarding the Signal attenuation would be appreciated. 🙂
1 REPLY 1
Message 2 of 2
Re: Signal attenuation showing a minus value?
No idea, but it's a meaningless parameter in any case.
