bus-error
Message 1 of 1
Significant Drop in Upstream Speed - how to resolve?
Hi folks,
I can see from my router logs that on August 5th at 09:06 my VDSL dropped and reconnected with a significantly slower upstream speed. Before the drop it was ~7.8Mbps, afterwards it was ~3.4Mbps. Here are the log entries:
Aug  5 09:02:27 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=7830000 DownSpeed=49495000 SNR=5 Atten=19 ]
Aug  5 09:02:55 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=7830000 DownSpeed=49495000 SNR=5 Atten=19 ]
Aug  5 09:03:23 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=7830000 DownSpeed=49495000 SNR=5 Atten=19 ]
Aug  5 09:03:50 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=7830000 DownSpeed=49495000 SNR=5 Atten=19 ]
Aug  5 09:04:19 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=7830000 DownSpeed=49495000 SNR=5 Atten=19 ]
Aug  5 09:04:47 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=7830000 DownSpeed=49495000 SNR=5 Atten=19 ]
Aug  5 09:05:14 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=7830000 DownSpeed=49495000 SNR=5 Atten=19 ]
Aug  5 09:05:35 vigor.router DrayTek: PPP Closed : Remote Terminating (PPPoE)
Aug  5 09:06:07 vigor.router DrayTek: >>> Dial-up triggered by user : 192.168.0.135 ; proto=TCP, to 52.114.74.38 port=443
Aug  5 09:06:10 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=7998000 DownSpeed=50073000 SNR=4 Atten=19 ]
Aug  5 09:06:29 vigor.router DrayTek: PPP Closed : Remote Terminating (PPPoE)
Aug  5 09:07:05 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=3414000 DownSpeed=48053000 SNR=4 Atten=19 ]
Aug  5 09:07:29 vigor.router DrayTek: PPP Start (PPPoE)
Aug  5 09:07:29 vigor.router DrayTek: CHAP Login OK (PPPoE)
Aug  5 09:07:29 vigor.router DrayTek: IPCP Opening (PPPoE); Own IP Address : 213.122.143.156  Peer IP Address : 172.16.12.108; Primary DNS : 81.139.57.100  Secondary DNS : 81.139.56.100
Aug  5 09:07:33 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=3414000 DownSpeed=48053000 SNR=5 Atten=19 ]
Aug  5 09:08:06 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=3414000 DownSpeed=48053000 SNR=5 Atten=19 ]
Aug  5 09:08:34 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=3414000 DownSpeed=48053000 SNR=4 Atten=19 ]
Aug  5 09:09:02 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=3414000 DownSpeed=48053000 SNR=4 Atten=19 ]
Aug  5 09:09:30 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=3414000 DownSpeed=48053000 SNR=4 Atten=19 ]
Aug  5 09:09:58 vigor.router DrayTek: ADSL_Status:[Mode=17A States=SHOWTIME UpSpeed=3414000 DownSpeed=48053000 SNR=4 Atten=19 ]
I would have been at work at the time so I can confidently say that this is not the result of anything I have changed and suspect that something changed in the network. How best would I get OpenReach to look into this?
Many thanks
Bruce
