rachelhutson
Message 1 of 4
Since yesterday customers on BT infinity accessing RD Gateway get certificate revocation errors.
Has anyone else found the same thing? The ONLY common link is that customers on a BT infinity link cannot access our RD Gateway. A stabdard BT broadband account is fine, and any other ISP is fine. What has changed on the BT network??
3 REPLIES 3
Moderator-Retired
Message 2 of 4
Re: Since yesterday customers on BT infinity accessing RD Gateway get certificate revocation errors.
Hi Rachelhutson,
Thanks for posting. I am sorry to hear your having issues with your Infinity accessing RD Gateway.
Is this issue still happening?, if so can you provide what type of Hub you are using and if you recently got a firmware update?
PaulK
BTCare Community Mod
If we have asked you to email us with your details, please make sure you are logged in to the forum, otherwise you will not be able to see our ‘Contact Us’ link within our profiles.
We are sorry but we are unable to deal with service/account queries via the private message(PM) function so please don't PM your account info, we need to deal with this via our email account 🙂
rachelhutson
Message 3 of 4
We had to make a change on our end to allow the traffic back through - but it was odd it was only affecting BT infinity customers - a number of sites and routers. This is why we thought a change was made on the BT network.
We had to change a configuration settings on the network card.
Go to – Network and Sharing Center -> Change Adapter Settings -> Right click on the card -> Properties -> Configure -> Advanced Tab -> Large Send Offload V2 -> Set to Disabled
Moderator-Retired
Message 4 of 4
Hi rachelhutson,
Thanks for the update, if the issue returns post on hear and let me know.
PaulK
