Newbie
Message 1 of 7
Size of hole for fibre optic cable
Hello
I'm going to switch to ultrafast, so a fibre modem needs to be installed. Does anyone know what size hole openreach  drill thru the wall for the cable as I'd like to drill it myself beforehand
6 REPLIES 6
Sage
Message 2 of 7
Re: Size of hole for fibre optic cable
@Pingpong404 wrote:
Hello
Is the Ultrafast product being supplied via FTTP or over copper from a G.Fast pod at the cab? If FTTP will you be drilling the hole in the correct place for FTTP to enter?
Newbie
Message 3 of 7
Fttp. I'm reasonably confident about the hole placement - it will be at the front on the house about 70cm above ground thru the wall into a cupboard with power and is in line with the current overhead drop wire hanger. The current copper goes thru a window frame. If I do the drilling i can take my time so it will be neat and correctly angled to prevent damp bridging.
Sage
Message 4 of 7
Should be in HERE somewhere.
Newbie
Message 5 of 7
Thanks for a useful document. If anyone else wants to know - Wiring through cavity walls must be installed within 20mm conduit
Newbie
Message 6 of 7
link is not working.
Sage
Message 7 of 7
The website has been re-designed. Depending on what you want to know there should be a guide or handbook for it HERE.
