Message 1 of 11
Sky Q not connecting
Sky q has stopped connecting to internet nut all devices are still  connecting perfectly . Have tried connecting with Ethernet and still no joy.
sky are telling me that it's a fault with BT broard band but why would it still connect to other devices ?...
10 REPLIES 10
Message 2 of 11
Re: Sky Q not connecting
Hi @Karenlm   Have you rebooted the router? It doesn’t matter that other devices work okay. Obviously followed by the Sky Q box.
Message 3 of 11
Hi yes many times - it's been ongoing for over a month now
Message 4 of 11
I would say bt are correct here if everything else connects besides the sky box especially over etherneg I would say that's your issue
Message 5 of 11
as SKYQ uses channel 36 have you changed your wifi 5ghz channel from smart to a channel other than 36 say 48?
Message 6 of 11
I don't think so - well not to my knowledge - where would I be able to check ? Many thanks
Message 7 of 11
I feel like I'm being batted from one to the other !
Message 8 of 11
Advanced wireless settings in the hub manager.
192.168.1.254
Message 9 of 11
What are the details when you go to SkyQ settings/setup/Network/Advanced Settings/Set Manually
It should list IP Address, Subnet Mask, Router, DNS Server
Message 10 of 11
Yes that is correct  thankyou
