Badgerbroadband
Message 1 of 29
Slow Broadband - recent line problems, which were fixed.
Recently, last few weeks, our broadband would drop out. BT openreach found a fault on our line and fixed it on the 27th July. Our speeds at that point became very low 0.29/2.56Mbps. Engineer said to call BT for a reset. After many calls in which the people kept trying to book in an engineer, they said they would reset it and email me. No email appeared, but i left it for a bit to see. The speed has gone up to 15Mbps, but feel it should be higher as I'm sure my minimum promised was in the 30's. My problem is we never looked at speeds before our problems. Has a DLM reset happened? If this is the service I'm going to get should I be looking for money back?
We have superfast fibre 1 unlimited - on the web it stated average speeds of 50?!?
Can someone suggest my next action please. Have I had a reset? How would I check?
Product name:
BT Hub 6A
Serial number:
+084319+NQ63615609
Firmware version:
SG4B1000B540
Firmware updated:
29-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
1 Days, 2 Hours 42 Minutes 45 Seconds
Data rate:
1.29 Mbps / 15.00 Mbps
Maximum data rate:
1706 / 19484
Noise margin:
7.8 dB / 8.2 dB
Line attenuation:
22.4 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
16988 MB Uploaded / 140566 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-GXFT
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-GXFT
5 GHz wireless channel:
Smart (Channel 40)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
88:A6:C6:2C:FF:8B
Software variant:
Boot loader:
7.33.1
28 REPLIES 28
Message 2 of 29
Re: Slow Broadband - recent line problems, which were fixed.
enter your phone number nad post results  remember delete number but leave exchange and cab  https://www.btwholesale.com/includes/adsl/main.html
the speed average you quoted is an average meaning there will bee customers with loer na others with higher speed hence average  your speed will depend on what your line can handle
Guru
Message 3 of 29
Seeing as you had a repair (and line intervention) ... what should have happened is the engineer in question request to BTo for a caution counter reset. Problem is some engineers who are broadband trained at BTo can do it from their JDSU, whilst line engineers who are not trained cannot. Unfortunately most broadband problems can get away without one, but where the intervention has caused massive drop in linespeed as in your case ... relying on a natural DLM recovery is a tad unfair.
If you've had no email from BTo regarding the intervention, I would be looking to contact a forum moderator, who is employed by BT on this forum ... who will either expedite that reset via BTo, or use alternate means to do so.
Otherwise ... it could take a while.  One for flagging methinks.
Badgerbroadband
Message 4 of 29
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
45.1
32.4
8.8
5.9
28.5
Available
Available
VDSL Range B (Impacted)
35.7
20
8.1
4.3
15
Available
Available
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 7
4.5 to 11
Available
WBC ADSL 2+ Annex M
Up to 7
Up to 1
4.5 to 11
Available
ADSL Max
Up to 5.5
4 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise environment
Status
Bridge Tap
Y
VRI
N
NTEFaceplate
N
Last Test Date
25-07-2018
Badgerbroadband
Message 5 of 29
How do I flag this moderators?
Guru
Message 6 of 29
I did it ... 😉
Badgerbroadband
Message 7 of 29
Thanks!
Guru
Message 8 of 29
The moderators are busy folks, and weekend approaches, just wait to see an invite link in this thread to make contact ... takes a day or three. 😉
Moderator
Moderator
Message 9 of 29
@Badgerbroadband I'm only seeing your post now sorry about the delay replying.  Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Badgerbroadband
Message 10 of 29
Have clicked on the link in your username and given details
