Message 1 of 2
Slow / Buffering connection rebboting router every day now just to work
Hi all,
I have 75mb fiber direct to my house (FTTP)
speed test comes back with around 70 - 74mb each time but if you try to open anything on youtube / facebook / ebay etc it just hangs for a around 25seconds and then slowly opend the picture / stream.
online line gaming (pc or xbox) is just a joke now
This has been going on now for about 2 months , and i'm rebooting everything daily just so I can work !
Ive just tried the speedtest at speedtest.net and it just sits there pulsing the blue circle tryitn to get a connection
My setup is
openreach fiber modem to Linksys EA9500
EA9500 with cat6 to Netgear Gigabite 24 port hub
PC , Xbox, TV are all hardwired via cat6 to hub (so no lag or wifi issue)
I also have spare a BT home hub 4 and 5 plus a linksys e6350
I have tried all 4 routers and the buffer / slow transfer is the same on all of them, Ive tried the dsl report speed test and it gives me a buffer bloat of over 200 ,
Ive also tried changing the dns to goole , opendns and via a vpn but no improvment,
does anyone have any ideas what to try or who at BT will actualy help 🙂
Dave
1 REPLY 1
Message 2 of 2
Re: Slow / Buffering connection rebboting router every day now just to work
Just an update,
I have just tried the speed checker at https://www.speedtest.btwholesale.com/
out of 10 trys 7 were over 60ms ping the remaing 3 were in the mid 20ms
I used to get 7 - 9 ms max
