Eifion
Message 1 of 23
Slow Connection
Hello,
I think i might have a problem with my connection.  I have tried the quiet line test and there is barely any noise at all if any that i can hear.  Below are the stats from my HH5A and the line stats:
3. Firmware version:Software version 4.7.5.1.83.8.264 (Type A) Last updated 09/08/19
4. Board version:BT Hub 5A
5. DSL uptime:2 days, 19:29:29
6. Data rate:16756 / 40000
7. Maximum data rate:16657 / 76905
8. Noise margin:6.0 / 13.5
9. Line attenuation:14.7 / 13.5
10. Signal attenuation:14.9 / 14.0
11. Data sent/received:951.6 MB / 16.6 GB
VDSL Range A (Clean)8067201961.2AvailableAvailable--
VDSL Range B (Impacted)8065.6201959.7AvailableAvailable--
G.fast Range A (Clean)204.8155.430.913.1134.1AmberAmber--
G.fast Range B (Impacted)17311920.59.9104.8AmberAmber--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 6--5 to 7Available----
WBC ADSL 2+ Annex MUp to 6Up to 15 to 7Available----
WBC Fixed Rate2----Available----
Max Observed Downstream Speed (Mbps)--40
Max Upstream Observed Speed (Mbps)--16.49
Observed Date--2019-08-10
VDSL Multicast------Available----
ADSL Multicast------Available----
G.fast Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date22-08-2019
I have tired the BT online chat and they are sending me a new HH6, but i doubt that will solve the problem.  They were going to send an engineer out but that was cancelled (without notice to me) as they had fixed the fault remotely.  I can see no difference.  Could someone with a little more knowledge look at the stats above and advise me if there may be a line issue the hub is connected directly to the master socket via a filter with a telephone no extensions.
Many thanks
22 REPLIES 22
Message 2 of 23
Re: Slow Connection
first glance suggests a banded profile probably due to hub dropping internet connection often or manual reset trying to restore speed or a combination of both  your connection time is only 2 days was that manual reset?
Eifion
Message 3 of 23
Re: Slow Connection
Thanks for the response.  Yes 2 days ago i restarted the hub as requested by the online chat.  What is a banded profile ?  Having read a little i thought that the profile was set by your connection speed ?
Message 4 of 23
Re: Slow Connection
this may help   https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
Eifion
Message 5 of 23
Re: Slow Connection
Thanks for the link which i have read.  So i could be stuck on this band due to either a noisy line (no noise on the quiet line test) or excessive error or the hub rebooting.  I seem to have been stuck on this band since June, before which i had 65Mb connection for months.  Before the reset 2 days ago the hub had been on for 15 days at least.  What can i do ?
Moderator
Moderator
Message 6 of 23
Re: Slow Connection
Hi @Eifion,
Welcome back to the Community.
Sorry to hear that you are having problems with your connection.
Can you confirm that you are plugged into the master socket and also complete the Home Checks and let me know how you get on?
Matt
Community ModeratorMatt
Show your appreciation!
Kudos”Kudos”
Eifion
Message 7 of 23
Re: Slow Connection
Yes - filter plugged into the master socket with HH5A plugged into filter and one phone.  No extensions.
Moderator
Moderator
Message 8 of 23
Re: Slow Connection
Were you able to complete the home checks and plug into the test socket?
Matt
Kudos”Kudos”
Eifion
Message 9 of 23
Re: Slow Connection
Yes - the HH5A is plugged into the test socket and i've been through the home helps
Moderator
Moderator
Message 10 of 23
Re: Slow Connection
Thanks for completing all the home checks.
I've sent you a Private Message with details on how you can get in contact with the mod team.
Matt
Kudos”Kudos”
