Eifion
Message 11 of 23
Re: Slow Connection
Matt,
Thanks for the PM and i have responded with the details.
Regards
Eifion
Eifion
Message 12 of 23
Re: Slow Connection
Seems I was stuck in the banded profile. Download connection is now at 67Mb rather than 40Mb. Won't touch the hub or line for a few days to allow line to settle. Thanks for all the help.
Moderator
Moderator
Message 13 of 23
Re: Slow Connection
You are welcome @Eifion
Glad I could help out 😊
All the best,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Eifion
Message 14 of 23
Re: Slow Connection
I noticed this morning that the HH5 had re-synced and the download speed is now 61Mb.  I guess that DLM (?) is adjusting the speed down due to line conditions ?  At what point if any could it be suggested that there is an issue with the line or if it goes back down to 40Mb given that the maximum should by 77Mb then thats is what i can always expect ?
Many thanks
Eifion
Sage
Sage
Message 15 of 23
Re: Slow Connection
You should expect sync speed to be above 60Mb and noise margin of 6.0dB or less.
Eifion
Message 16 of 23
Re: Slow Connection
The sync speed was 67Mb last night with a noise margin of 5.8dB, but this morning the line had resynced at 61Mb and again noise margin at 5.8dB.
Sage
Sage
Message 17 of 23
Re: Slow Connection
Which exchange and cab number?
Eifion
Message 18 of 23
Re: Slow Connection
I think its Taunton 48
Sage
Sage
Message 19 of 23
Re: Slow Connection
ECI cab so no G.Inp to wait for. See how it settles over the next few days.
Eifion
Message 20 of 23
Re: Slow Connection
The down connection speed has dropped to 55Mb, the SNR is about 6.8.  What does the handover threshold mean?
