Gazzap45
Message 1 of 10
Slow Fibre
Ok, this has been going on for a while now can some one please take a look at my connection?
I am on superfast fibre unlimited 2
Connected at test socket stats are:
DSL synchronization status: Up
Connection status: Showtime
Upstream line rate (kbit/s): 19998
Downstream line rate (kbit/s): 34998
Maximum upstream rate (kbit/s): 20166
Maximum downstream rate (kbit/s): 70620
Upstream noise safety coefficient (dB): 6
Downstream noise safety coefficient (dB): 13.6
Upstream interleave depth: 0
Downstream interleave depth: 0
Line standard: VDSL
Upstream line attenuation (dB): 23.5
Downstream line attenuation (dB): 11.5
Upstream output power (dBm): 6.8
Downstream output power (dBm): 12.7
Channel type: None
DSL up-time: 7 days 13 hours 29 minutes 35 seconds
9 REPLIES 9
Distinguished Guru
Distinguished Guru
Message 2 of 10
Re: Slow Fibre
Do you have a dial tone?
Have you tried a quiet line test (best with corded phone)? 17070 option 2.
Have to connected to the test socket with filter to see if that improves your connection?.
Gazzap45
Message 3 of 10
Re: Slow Fibre
The one thing I forgot to mention, quiet line test done,no pops, crackles or anything else and is conneted to test socket with filter.
Distinguished Guru
Distinguished Guru
Message 4 of 10
Re: Slow Fibre
That's 2 things actually.
As your connection rate is below the handback ring in and get an engineer out.
Moderator
Moderator
Message 5 of 10
Re: Slow Fibre
@Gazzap45 if you need any help with this please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 6 of 10
Re: Slow Fibre
your current connection time appears to be 7days but have you previously been having conenction problems with router dropping connection or manually resetting router to try and improve speed or maybe both?
Gazzap45
Message 7 of 10
Re: Slow Fibre
It re synced at that time, went up to 50 odd but didnt hold it. Did have a delivery driver break the cable from the pole to the house, that is when I started looking at speeds, must admit can not remember what sync speed I was getting before that. Oh and have been leaving the router to do its own thing, don't want to mess with it because of the fear of DLM.
Message 8 of 10
Re: Slow Fibre
from stats looks like the DLM has already taken action following the problems with the line
take up mod offer of help and complete form  best way to get speed back within estimated range
Gazzap45
Message 9 of 10
Re: Slow Fibre
Contatcted
Moderator
Moderator
Message 10 of 10
Re: Slow Fibre
Hi @Gazzap45
Tried calling today sorry I missed you, speeds look to have greatly improved since we last spoke, how have you found the connection performance over the weekend?
Stuart
Community ModeratorStuartH
Kudos”Kudos”
