dombullion
Message 1 of 11
Slow Speed on Faster Total Broadband (AKA FTTC)
Hello All,
Please welcome me back to the forums- been a while.
Our Speed has suddenly dropped on all devices to around 6-7mbps yet when the line was first installed by the engineer we were getting 15mbps.
Here are line stats from Hub5:
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34523257
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 17/08/14
4. Board version:BT Hub 5A
5. VDSL uptime:2 days, 07:55:46
6. Data rate:774 / 7896
7. Maximum data rate:862 / 14716
8. Noise margin:6.0 / 9.7
9. Line attenuation:0.0 / 32.0
10. Signal attenuation:0.0 / 25.9
11. Data sent/received:1.1 GB / 1.8 GB
12. Broadband username:
bthomehub@btbroadband.com
Here is speedtest result done at speedtest.btwholesale.com:
1. Best Effort Test:  -provides background information.
 Download Speed
 7.43 Mbps
0 Mbps7.64 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 7.43 Mbps
 For your connection, the acceptable range of speedsis 5.35 Mbps-7.64 Mbps .
 Additional Information:
 IP Profile for your line is - 7.64 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.68 Mbps
0 Mbps2 Mbps
Upload speed achieved during the test was - 0.68Mbps
 Upstream Rate IP profile on your line is - 2 Mbps
hope someone can help with this.
Thanks in advance,
Dom.
10 REPLIES 10
Distinguished Guru
Message 2 of 11
Re: Slow Speed on Faster Total Broadband (AKA FTTC)
The target noise margin is 6 but yours is 9.7 which indicates DLM has capped your line due to some disconnections it has counted.
Once the instability has ceased, DLM will raise your speed over the following 2 weeks.
If not, I'll try again 🙂
dombullion
Message 3 of 11
Hi ray_dorset,
Will it take 2 weeks for the DLM to detect the line as stable and then will it gradually increase the speed?
Dominic.
Distinguished Guru
Message 4 of 11
No, DLM starts counting the days as soon as your line is stable, then 2 weeks later you should be back to full speed.
Message 5 of 11
this explains more about the DLM and how it works http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
dombullion
Message 6 of 11
Hello,
Speed seems to have gone up but the IP Profile is the same.
Here is a speed test done at speedtest.btwholesale.com:
 Download Speed
 10.84 Mbps
0 Mbps7.63 Mbps
 Download speedachieved during the test was - 10.84 Mbps
 For your connection, the acceptable range of speedsis 5.34 Mbps-7.63 Mbps .
 IP Profile for your line is - 7.63 Mbps
 Upload Speed
 0.66 Mbps
0 Mbps2 Mbps
Upload speed achieved during the test was - 0.66Mbps
here are router stats from Hub5:
5. VDSL uptime:0 days, 03:52:50
6. Data rate:714 / 11398
7. Maximum data rate:860 / 14093
8. Noise margin:6.4 / 6.7
9. Line attenuation:0.0 / 31.9
10. Signal attenuation:0.0 / 25.8
11. Data sent/received:1.2 GB / 1.9 GB
12. Broadband username:bthomehub@btbroadband.com
I haven't rebooted the router so looks like the DSLAM at the exchange did an automatic reset.
Hope someone can advise further.
Thanks,
Dominic
dombullion
Message 7 of 11
Any reply to this please.
shirts
Recognised Expert
Message 8 of 11
Welcome back to the forums dombullion......Smiley Wink
As ray_dorset already said, the dlm will check (every 15 minutes I believe) your line and it is only when it sees a stable connection, will it increase your speeds although it may well fluctuate until it sees a stable connection.....
Can you carry out the "quiet line" test ? Using a corded phone plugged into the test socket on the master socket, dial 17070 and choose option 2. There should be no crackles, popping, buzzing, etc, in fact, it should be quiet........
If you found this post helpful, then please click the star on the left, after all, I'm only trying to help........Smiley Wink
dombullion
Message 9 of 11
Quiet line test is well Quiet. No buzzing etc on the line.
Thanks.
shirts
Recognised Expert
Message 10 of 11
Can you describe your home wiring ? ie any extentions etc.....
