fregrin
Message 1 of 17
Slow Speed
Hello,
With sky fibre i had around 28-30mbps but am only able to get 6-7mbps with BT. I have a brand new latest openreach master socket, an engineer been out and done tests from my home to exchange. Am at a loss as why is slow, i understand within ten days but would expected by now get better speed after 5 days.
16 REPLIES 16
pippincp
Sage
Message 2 of 17
Re: Slow Speed
Can you post the connection stats from the hub.
HH6 Advanced settings/technical log.
fregrin
Message 3 of 17
Re: Slow Speed
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ83247187
Firmware version:
SG4B1000B540
Firmware updated:
23-Oct-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
2 Days, 6 Hours 58 Minutes 23 Seconds
Data rate:
1.26 Mbps / 8.75 Mbps
Maximum data rate:
1254 / 17863
Noise margin:
7.7 dB / 19.9 dB
Line attenuation:
28.9 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
1420 MB Uploaded / 20724 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-K7S7
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-K7S7
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
D8:7D:7F:C0:70:17
Software variant:
Boot loader:
9.2.0
pippincp
Sage
Message 4 of 17
Re: Slow Speed
There's obviously something wrong with your line so only 2 reasonably checks to do. Remove the faceplate and the interim plate and connect to the test socket with a filter. Do a quiet line test 17070 option2, best with corded phone but if with cordless may get a background hum. Any noise report a line fault on 151 don't mention broadband as you will be put through to the wrong dept.
Repost stats while in test socket.
fregrin
Message 5 of 17
Re: Slow Speed
ok I did as you asked and am now in test socket, the line test i couldnt hear anything apart from buzz or hum and wasnt sure if that was my corded phone its very cheap dont normally use the landline.
These are  stats just after reconnecting via the test socket as requested.
Product name:
BT Hub 6A
Serial number:
+084316+NQ83247187
Firmware version:
SG4B1000B540
Firmware updated:
23-Oct-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 2 Minutes 1 Seconds
Data rate:
1.25 Mbps / 9.34 Mbps
Maximum data rate:
1251 / 9535
Noise margin:
7.9 dB / 6.4 dB
Line attenuation:
28.8 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
4099 MB Uploaded / 24577 MB Downloaded
Broadband username:
BT Wi-fi:
Not active
BTHub6-K7S7
Smart (Channel 11)
BTHub6-K7S7
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
D8:7D:7F:C0:70:17
Software variant:
Boot loader:
9.2.0
Techwizz
Message 6 of 17
Re: Slow Speed
Very rare to see worse stats in the test socket (lower maximum downstream rate), which would suggest that there's a wiring problem with the socket. Quiet line tests carried out with a corded phone should be completely silent. Can you try completing the test with the face plate connected? Regardless of what ever is causing the problem, the higher downstream maximum data rate is only just above the handback threshold, which even if the line was connected at the target SNRM. Taking into account overheads would mean that it's very likely that your line wouldn't connect at the threshold anyway, meaning that you would be entitled to an engineer.
fregrin
Message 7 of 17
Re: Slow Speed
no idea , sent engineer once already maybe i can ask them replace or re wire my socket
fregrin
Message 8 of 17
Re: Slow Speed
ok i reattached faceplate ran line test again , still have hmm/buzz and its like i dunno so faint hard to tell but someone talking in distance..very very hard to hear so faint.
Anyway these are my stats now after attaching faceplate again..
Product name:
BT Hub 6A
Serial number:
+084316+NQ83247187
Firmware version:
SG4B1000B540
Firmware updated:
23-Oct-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 2 Minutes 50 Seconds
Data rate:
1.25 Mbps / 8.49 Mbps
Maximum data rate:
1247 / 8877
Noise margin:
8 dB / 6.4 dB
Line attenuation:
28.9 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
8192 MB Uploaded / 28675 MB Downloaded
Broadband username:
BT Wi-fi:
Not active
BTHub6-K7S7
Smart (Channel 11)
BTHub6-K7S7
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
D8:7D:7F:C0:70:17
Software variant:
Boot loader:
9.2.0
RobbieMac
Moderator
Moderator
Message 9 of 17
Re: Slow Speed
Hi @fregrin,
Thanks for your posts and welcome back!
Sorry that your broadband speed isn't performing near the speed we told you you'd get when you placed your order.  It's a strange one as connecting to the test socket gave you a slower speed than what you were seeing connected to the socket normally.  That doesn't happen very often for sure @Techwizz
Can you send us over your details and we'll look at your connection from here?  Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
fregrin
Message 10 of 17
Re: Slow Speed
sent you message assuming did it right
