eddywatson
Message 1 of 7
Slow Speeds 01642 area code
Hello
Yesturday and today Ive experienced very slow speeds for downloading, streaming is decent and so is web browsing.... normally my download speeds are 100% fine but these two days its been about 600kbs consistant normally I would be hitting 8/9mbs
is there a problem within my area code? 01642, Stockton on tees?
Thank you
6 REPLIES 6
Message 2 of 7
Re: Slow Speeds 01642 area code
From one site or multiple?
eddywatson
Message 3 of 7
any site, its seems my whole internet has gone slow.
it went from fine to slow, just as simple as that
Message 4 of 7
Can you run a speedtest with a wired connection at http://speedtest.btwholesale.com ensuring you run the further diagnostics test.
Post up a screenshot of the results once completed please.
eddywatson
Message 5 of 7
Download Speed: 41.37
Upload Speed: 12.26
PING: 24.00
Sage
Sage
Message 6 of 7
Further diagnostic test results???
eddywatson
Message 7 of 7
1. Best Effort Test:
Download Speed : 43.03 Mbps
2. Upstream Test:
Upload Speed : 11.81 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
