kauserabdin
Newbie
Message 1 of 7
Slow Speeds
Hello,
Recently, my internet connection become super slow, here are my results:
VDSL Range A (Clean)66.145.815.19.740AvailableAvailable--
VDSL Range B (Impacted)63.44014.98.532.4AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 10--8 to 12.5Available----
WBC ADSL 2+ Annex MUp to 10Up to 18 to 12.5Available----
ADSL MaxUp to 6--5 to 8Available----
WBC Fixed Rate2 ----Available----
Max Observed Downstream Speed (Mbps)21.59
Max Upstream Observed Speed (Mbps)9
Observed Date2019-09-07
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date30-08-2019
The Max observed downstream us usually in the 45 range but now has been cut in half. The readings are in-line with what I view on my router:
  Upstream Downstream
Current Rate(kbps)906421529
Max Rate(kbps)897021160
SNR Margin(dB)5.95.8
Line Attenuation(dB)3018.9
Errors(pkts)016
Any ideas on how this can be resolved and what caused this issue?
Thanks,
Kauser
6 REPLIES 6
kauserabdin
Newbie
Message 2 of 7
Re: Slow Speeds
Hi,
I would appreciate if anyone had any thoughts? Thanks
Message 3 of 7
Re: Slow Speeds
@kauserabdin
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
I would not be surprised if you found you did not get any dial tone on your phone.
Message 4 of 7
Re: Slow Speeds
assuming you do get a dial tone have you tried connecting to the test socket with filter to see if that helps.
kauserabdin
Newbie
Message 5 of 7
Re: Slow Speeds
HI Keith,
Thank you for replying.
I've dialed the number and hear a slight bit of noise on the line, but nothing major. This drop in speeds has occurred rather recently from last week, I am tempted to give BT a call to speak to an engineer if theres no other solutions.
Thanks,
Kauser
Sage
Sage
Message 6 of 7
Re: Slow Speeds
Even the slightest noise can have a big effect on broadband speed depending on the frequency of the noise. Report a noisy line on 151, as the engineers do not work for BT you won't be able to talk to one until he visits your property.
Message 7 of 7
Re: Slow Speeds
You need to check at the test socket, just in case you have an issue with your internal wiring.
See http://bt.custhelp.com/app/answers/detail/a_id/40231/%7E/home-wiring-and-broadband-set-up---a-checkl...
