Message 1 of 5
Slow broadband connection
Connection down to 5.2MB "speed to hub" according to BT app
Tried line noise test - should there be ANY noise at all? I can hear a very low level white noise - does that mean a problem or not?
Stats from router
Product name:
BT Hub 6A
Serial number:
+084319+NQ92745233
Firmware version:
SG4B1000E020
Firmware updated:
10-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
2 Days, 14 Hours 28 Minutes 49 Seconds
Data rate:
10.00 Mbps / 55.00 Mbps
Maximum data rate:
11932 / 56726
Noise margin:
7.7 dB / 3.8 dB
Line attenuation:
38.4 dB
Signal attenuation:
27.3 dB / 38.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
3 GB Uploaded / 59 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-MWM2
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-MWM2
5 GHz wireless channel:
Channel 48
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
D0:57:94:C9:07:03
Software variant:
Boot loader:
0.48.8-sec
4 REPLIES 4
Message 2 of 5
Re: Slow broadband connection
your hub stats show you are on fibre 1 with the max connection speed of 55/10mb
is the 5.2mb an actual download speed while downloading from a website?
run btspeedtester and post results  must be done with ethernet cable
https://www.speedtest.btwholesale.com/
Message 3 of 5
The speed is as reported from the BT speed test within the My BT app
Message 4 of 5
BTW I have a fault raised on Monday morning. On "Track my fault" there is no info about any timeline - when should I expect some info about the timeline to deal with the fault?
Message 5 of 5
if that was on wifi you need to run the test using link I provided but must be with ethernet connection not wireless
from your stats there is no fault as you have the maximum connection speed for your fibre 1 contract
