AndrewLBuck123
Message 1 of 7
Slow broadband speed
Hi All,
My first post as a newbie, reported to BT that I have very slow Infity 2 speed circa 2Mbs. BT engineer called today to investigate, found a problem with line from external connection box to the main socked inside house. Engineer replaced with new cable and a new main box.
Speed check at the external box was 29.87 and 30.56 Mbs, speed at the main box inside house almost identical to within a few Mbs. On switching on laptop and checking speed using BT wholesale speed checker we got speeds of 15.5 and 15.3Mbs? engineer at a loss to why we were loosing almost 50% line speed from the main socked to the router on a cable length  of under 1M. Cable from main box to router is standard flat wire RJ11 to RJ45 supplied by BT with home hub 6 router.
Anyone else have experience of this type of line speed loss or have any ideas how to get back the lost 15Mbs.
Thanks,
Andy
6 REPLIES 6
Message 2 of 7
Re: Slow broadband speed
Post stats from hh6 advanced settings then technical log information
run btspeedtester diagnostic test and post results. Must be done with wired connection not wireless
AndrewLBuck123
Message 3 of 7
See below results from BT Speed checker:
Download 10.51Mbs
Upload 2.23Mbs
Latency 69ms
Message 4 of 7
Can you post full diagnostic resulted please not just first test
AndrewLBuck123
Message 5 of 7
Sorry but that is the only infor I got from the BT speed checker, what other tests results should I be able to see.
Thanks for your patience,
Andy
AndrewLBuck123
Message 6 of 7
Well just rerun the speed checker and tried to run the further tests, however I get a message the 'site is not secure' ?? and stops and will not run the further tests. So it would seem I am stumped and unable to gather the info you are asking for.
Not sure how to go forward from here.
Regards,
Andy
Message 7 of 7
did you try using a different browser?
can you post the hub stats
