Message 1 of 17
Slow broadband
Hello,
I've been referred here instead of calling about slow speeds. For at least a week now I have been getting speeds of 8mb or less on my 50mb fibre, through both wireless and wired. With two home workers and home schooling we are struggling. Is there any solution or help please? Thanks
16 REPLIES 16
Message 2 of 17
Re: Slow broadband
Post hub stats. If hh5 then troubleshooting then helpdesk. If hh6 then advanced settings then technical log information
check for line noise. Dial 17070 option 2 should be silent and best with corded
enter phone number and post results remember delete number.    https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 3 of 17
Re: Slow broadband
Thanks for responding. I don't have a home phone to test the line. Here is my technical information, followed by the broadband checker (I note data rate is 10 Mbps, however I have checked myBT and I am on fibre 1, 50 mbps - could this be the problem?)
Edit: image saved of broadbandchecker screenshot for ease: https://imgur.com/wDbaE1e
Product name:
BT Hub 6A
Serial number:
+084316+NQ91557043
Firmware version:
SG4B1000E020
Firmware updated:
20-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 15 Hours 7 Minutes 43 Seconds
Data rate:
10.00 Mbps / 10.00 Mbps
Maximum data rate:
33337 / 50650
Noise margin:
22.1 dB / 31.2 dB
Line attenuation:
24.8 dB
Signal attenuation:
15.6 dB / 24.8 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
267 MB Uploaded / 4 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-G7FQ
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-G7FQ
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
80:20:DA:B8:38:E9
Software variant:
Boot loader:
9.2.0
Telephone Number **** on Exchange SWINDON is served by Cabinet 157
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
G.fast Range A (Clean)
G.fast Range B (Impacted)
8064.5201959.1AvailableAvailable--
8061.4201955.2AvailableAvailable--
266.7193.140.618.7168.3AmberAmber--
222.4159.328.113.8144.6AmberAmber--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+ADSL MaxWBC Fixed RateFixed Rate
Up to 6.5--5.5 to 7.5AvailableAvailable--
Up to 3.5--2.5 to 6.5AvailableAvailable--
1----AvailableAvailable--
1----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
9.99
20
2020-04-26
Other Offerings Availability DateVDSL MulticastADSL MulticastG.fast Multicast
Available
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
U
N
N
07-04-2020
Thank you.
Message 4 of 17
Re: Slow broadband
This is most likely being caused by a noisy phone line, you will need to check usin a phone.
If the phone line is noisy or has a high resistance connection, then that will affect your broadband.
There are quite a few people that do not plug a house phone in to check dial tone every so often. This can cause issues with broadband. Also, if one wire has become disconnected (quite common), then that will cause no broadband,  constant disconnections, or a very low speed.
The solution is to get hold of a cheap (less than £10) wired phone, and plug it into the phone socket to see if you get dial tone.
Then dial 17070 (free call)  and select option 2, quiet line test, and see if there is any noise on the line.
If you do not get dial tone, or there is noise on the line, then you need to report it as either no dial tone, or a noisy line. Do not mention the broadband problem, otherwise it will end up in the wrong fault queue, and take much longer to be fixed. There are plenty of people who can fix phone faults, but not as many broadband people.
Once the phone fault is fixed, then the broadband will get better.
Message 5 of 17
Re: Slow broadband
Thanks for your response. I have managed to source (via social distancing) a phone and have a dial tone before dialling and a silent line to the quiet line test. It is however a wireless phone, but presumably that would create noise as apposed to having a quiet line?
Message 6 of 17
Re: Slow broadband
There may be a very slight background white noise on a wireless phone, but it should be barely audible.
If its quite noticeable, then that would tend to indicate a problem with your line.
Your connection speed has been reduced, because of this fault.
Message 7 of 17
Re: Slow broadband
Sorry, what is the fault? I have a silent line when i call the quiet test line (no noise). Thanks
Message 8 of 17
Re: Slow broadband
your connection time is only 15hrs is that due to a manual reset or hub dropping connection?  Have you noticed hub dropping connection often or have you been trying resets to get speed back or maybe a combination of both
have you tried using the test socket with a filter especially if you have extension sockets elsewhere in your home
Message 9 of 17
Re: Slow broadband
It was a manual reset to see if that solved the problem. I was noticing frequent drop out's about a week ago. It's not happened since but I think that's when the speed issues began. I'm plugged in to the master socket. I'm afraid i'm not totally sure what you mean by a test socket and filter. I have tried removing the cover and plugging straight in to the socket which had no impact. Thanks for your help so far. Do you have any suggestions how to fix the issue?
Message 10 of 17
Re: Slow broadband
which master socket do you have  https://www.bt.com/help/broadband/getting-set-up/home-networks/a-wired-home-network/what-type-of-mas...
